Question about OKI B4300 Led Printer
WE HAVE A OKI B4300 PRINTER IN OUR LAB (WE ARE A MEDICAL CLINIC). IT SEEMS TO BE STUCK IN SOME SORT OF LOOP. THE DISPLAY READS RAMCHECK AND INITIALIZING OVER AND OVER AGAIN
  • 55 Answers
If the printer has additional memory, remove the memory and reboot the printer. If the printer initializes, the ram memory may be defective. Try reseating the optional memory, if unit fails to initialize, memory option is defective.
If the printer does not have any additional memory, this "RAM CHECK" condition is probably being caused by a low voltage power supply problem. It is recommended to replace the low voltage power supply - part number 41991601.
Posted on Jan 12, 2009
I see a lot of these printers with this problem and its always the low voltage PSU, the capacitors on it have usually leaked, can sometimes be fixed by just replacing the blown capacitor
Posted on Jul 01, 2010
OKI B4300 Change paper
please keep the papers correctly aligned so that the sensors will recognize it...
good luck!!!!!!
dont forget to rate this
Aug 21, 2008 | OKI B4300 Led Printer
Oki B4300 LCD printer
Error 020 is a CU ROM Hash Check Error 1
It's most likely in need of circuit board replacement
If it's under warranty, contact the seller or
call 1-800-OKIDATA
Apr 05, 2008 | OKI B4300 Led Printer
Oki b4300 with error 173
Because you drum is worn out, and resetting the counter only forces the unit to keep working with weared consumables. A new drum unit is quite expensive, but it lasts 20,000 pages so the cost per print is low.
Mar 25, 2008 | OKI B4300 Led Printer
PRINTING
go to the maintanence menu and reset the drum count. every time you change the drum you have to do this.
Mar 07, 2008 | OKI B4300 Led Printer
Oki B4300 Will not power up...
Hi Rich,
Have you tried plugging this unit into a different outlet? maybe there is something wrong with your power?
Dezzi
Dec 09, 2007 | OKI B4300 Led Printer
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
Pages do not print clean on one edge
open it and clean the drum with a non scratching no-dust tissue with alcohol or similar
Aug 15, 2007 | OKI B4300 Led Printer
OKI B4300 Led Printer Logo
610 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
