Question about Victor 12403A Calculator
E keeps appearing after a few key strokes ona Victor 1240-3A
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
Victor vantage 148cc 4-stroke mower revving too hard
pull off the top cover and look a for some thing blocking the governor linkage
Apr 07, 2012 | Garden
Paper won't feed in Victor 1460-3. Calculator works fine otherwise.
There appears to be something in the way as the paper bunches up when I start to feed it through.
Is there some way of taking the back off this calculator?
Aug 17, 2011 | Victor 1460-3 Calculator
2 stroke Victor Mayfair Delux (old mower) Have cleaned our carbi. Plenty of petrol coming from. Can get it started but to keep it running with reasonable revs I have to keep the flooding device down with...
Hi, from your question it sounds like you have an idling problem. To fix this you have to adjust the idle speed screw that is located on top of the carb. Turn that screw in (clockwise) for faster idle speed. Hope this helps. All the best and good luck.
Feb 09, 2011 | Garden
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
Aug 24, 2010 | Victor 1560-6 Calculator
How much would a water pump cost for a 1992 audi s100
here is a list from autozone depending on the engine model.
Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $192.99 Part No. 8811 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $195.99
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140131_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140139_edb_8851_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8851 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $203.29
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140139_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140523_edb_8805_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8805 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $206.39
Apr 14, 2010 | 1992 Audi 100
VICTOR MILL JF-3VS I HAVE .005 PLAY UP AND DOWN
You could use a .004 shim stock spacer. I wouldn't worry about it as you are only milling and it should not have much impact!
Good luck, Jack
Aug 14, 2009 | Drills
My texas instrument TI 83 plus graphing calculator will not turn on. Put new batteries in and still wont work. What could be the problem?
Many TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Jan 26, 2009 | Victor 1430-3 Calculator
1570-05 not working
one of your keys stuck inside try to push all keys with your hand many times bring a good brand contact cleaner from (radio shack) or another electronic store and spray above all the keys while you are pressing the keys many times.(use dry contact cleaner)
Nov 16, 2007 | Victor 1570-5 Calculator
Victor 12403A Calculator Logo
53 people viewed this question
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
k24674
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
