Question about LG Washing Machines
Wf-t852a When the machine comes to the part where it has to pump out the dirty water it just dosent, unless i give it a kick in the lower back right side of the washing machine to get it going, i guess it may me the pump? would this be right? what part do I need?
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
john2072
  • 5 Answers
SOURCE: not spinning out water of Hotpoint WF 560 washing machine
pump problems
Posted on Jan 17, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
GodBlessU
  • 3513 Answers
SOURCE: error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue. God Bless.
Posted on Jul 09, 2009
Why won't my LG WF-T852A top loader washing machine fill with water ready to begin wash
Possibly the water inlet valve has burnt out .or the controller has failed . only a tech that has hands on capacity can tell for sure .
Jan 01, 2017 | LG Washing Machines
Front loading wash machine
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. (You may find the drain hose here, on left) The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Pl give me a nice rating for the free help!
Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Draining
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Mar 30, 2009 | Whirlpool Washing Machines
Code E20 appeared machine unable to drain, emptied water by hose at bottom of machine now unable to excess filter to check for any objects struck in filter any clues
Am giving you details of another machine, Frigidaire Affi, but you will surely find it useful. E20 is the same.
Mar 26, 2009 | Zanussi ZWF1430W Front Load Washer
Code E 20 Apperas and machine stops
Giving you solution for Frigidaire Affit, you will find it very helpful. Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. (You may find the drain hose here, on left) The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Mar 25, 2009 | Zanussi ZWF1430W Front Load Washer
Water not draining out
Mar 18, 2009 | Kenmore Washing Machines
Water keep refilling
Hi my name is joyce
you have a water valve problem just as you suspected its not shutting off your water when its supposed to it is just continually letting water come in your machine, also if you are on a well system check the back of your machine where your lines come into your machine their is a wire mesh filter that protects trash from getting into this valve, but sometimes it gets through this, so just uncrew the pipes and check this. I had this problem, if you dont have a filtration system on your house I would stongly recomend one to prevent this from happening again. I have a well and this has been a problem for me.
let me know if I can help with anything else,
joyce
Feb 05, 2009 | Washing Machines
E20 ERROR CODE
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle clothes washer
Feb 14, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
