My Philips model DVD750R/17 shuts off when playing a VCR tape after about 15 minutes. Why?
For no reason when playing a VCR movie it will shut down after about 15-20 minutes of playing.
    Top Expert:
  • 14,553 Answers
The most likely cause is a problem with the mechanism that moves the tape(when played a bit more weight is on the takeup reel.
Someone would have to open the unit so they can see the reels moving---watch to see if it begins to hesitate when further into the tape.
A trick that can help to see is put a fully rewound tape in and hit fast forward--let it go all the way to the end and rewind--if unit does not stop after doing that see what happens in play.
A worn drive unit that moves the tape can sometimes get better after run this way.
Posted on Dec 07, 2012
SOURCE:
  • 15 Answers
SOURCE: vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
Posted on May 13, 2007
SOURCE: I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
Hi All, I realize this post may be a bit late for some but I just bought this unit myself on 12-22-08. After reading the pdf manual I downloaded from an earlier post the description of "E1" and "E2" is on page 20 and more details are on pages 35 & 36.
"E1" is the display indicator the unit is looking for a External input signal or Line Mode. "E1" External input on the rear, "E2" External input on the front. No signal present so the unit shuts off.
I suggest changing/setting your record channel or source before starting any record mode steps. Hope this helps.
Sybrsound
Posted on Dec 23, 2008
SOURCE: magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
Try better quality VHS tapes or 6-hour tapes instead of 8-hour ones. I had this problem myself when I used 8 hour tapes, but haven't had any problems with the 6-hour ones.
Posted on May 17, 2009
  • 3 Answers
SOURCE: Power shuts off
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Craig Townsend
My zenith 4head vcr works, then stops
When a VCR encounters a mechanical problem, the electronics will stop playback and shut it down. I suspect that fault has developed in the mechanism and that the tape becomes jammed. The only way to find out it to take off the top cover and watch what happens when the video tape is played.
Dec 28, 2013 | Televison & Video
My sanyo vcr was working great until one day i put a movie in it and it played for about 30 seconds and shut itself off. Whats wrong?
VCR's shut themselves down when they encounter a problem. This is to prevent damage. In your case the mechanism might have jamned as it was trying to play the tape. The only solution is to look inside to see if the tape got tangled or damaged. Check also plastic parts for signs of damage too. Another cause is the mode switch. This tells the electronics what position the mechanism is in. If that goes wrong the VCR electronics will get confused and shut down the VCR. Cleaning the mode switch with Servisol can sometimes correct it, but sometimes it has to be replaced.
Mar 11, 2012 | Sanyo Televison & Video
VCR shuts down when tape loaded, "play" pressed...
could be dirty play heads and or rollers, run a wet cleaner through and see if this cures the problem.
Apr 08, 2010 | Philips Magnavox DVD/VCR Dual Player
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
Magnavox VCR/DVD recorder model ZV450mw8. VCR plays a tape for 6 seconds then shuts the whole unit down.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd/vcr
well sounds like one of the players is not in correct spot thus shuts down (kinda timing issue) see if there is anything preventing it from going jiggle or turn upside down see if you hear anything.
Feb 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Shuts down after 8 seconds of play.
Does the tape hang out when you eject the cassette?
8 seconds is about the time that the VCR brain allows the mechanism to run when there is a problem before shuting down. Just guessing from the model number, but I'd say the unit needs a belt job.
Dec 24, 2007 | Televison & Video
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Ekse
