Question about HP OfficeJet 7410 All-In-One InkJet Printer
Cannot power up
I turned off the machine to move it in the office. Now it will not turn on. The AC adaptor is puttimg out the required 30 volts and the screen on the front lights with the HP logo, however, it will not power up. I have unplugged it (all night) and that does not work
Is there some sort of reset with this machine?
Thanks
Ken Eigsti
  • 3 more comments
  • diverken Jan 12, 2009
    RE: No power up
    Ther power cord is not the solution.
    I had another adaptor and tried that and it still does not work. There is electricity getting to the machine as the front panel window is lit when I attach the cord.
    Thanks
    Ken
  • diverken Jan 19, 2009
    The solution posted did not fix the problem. I know there is power getting to the machine as the front window lights when power is applied. (How can this be the power cable?) However, the machine does not go any further in powering up. The green "ON" light does not light. Only indication of power is the window.
    The reset solution, wiggle power connector, hold # 6, does not solve the problem.
    None of the resets will work. The ON light will not come on, the only indication that power is getting to the machine is the little window lights with the HP logo. It is like there is a fuse or breaker that will not allow the machine to power up.
    I have tried different outlets etc. Remember, the window powers up.. so doesn't that mean that power is getting to the unit? Is there a chip or something that could have failed that is not going further with the power up? I think we can assume power is "getting" to the unit cause the window lights up? I am beginning to think it is a power supply problem within the unit. I have another identical ac/dc adaptor and have tried that with no success. The old adaptor is putting out the correct voltage (31 volts). I have another 7410 that I use as a spare. This machine is an integral part of my business, that is why I have a spare.
    Sergeant:
  • 221 Answers
turn the printer on and unplug the power cable from the back of the printer without turning the power off
press and hold :
OK and CANCEL, while keeping them on hold put the power cable back in ... it ll do a full NVRAM reset on it .. then it ll prompt u for the language and country follow the steps it ll be resolved .
if this does not solves your problem then the another fix you can try is to open the printer and this are the steps to follow just read it properly before trying  take the back panel off, there will be a bunch of ribbon connectors and plastic wire connectors. There will be one plastic connector set that has 5 or 6 wires and is wrapped in a black sheath. unplug this it is the wi-fi card. plug the machine back in and see if it boots right."
. The cable is located in the upper area of the small board on the back of the printer. It's a ribbon cable made of 5-6 coloured wires, all tied together with a black wrap.
Problem is apparently related to the Wi-Fi card. just  unplug the connector and all is good.
To access the connector remove the rear plastic access panel. To remove take out the two chrome looking screws. Then slide the plastic panel up to release the clips, then pull it out. You may have to play with it a little but it will come off.
The connector is at the very top of the circuit board located at the far LH side of the rear access area. It is the second (2nd) one from the back. It is white and has 5-6 colored wires that then go into a cable loom with heat shrink on the transition. Unplug the connector with pointed nose pliers and tie-wrap it back out of the way so that it cannot accidentilly short to anything.
Now, plug in the printer and see if you get pas the HP splash screen and the scrolling timing bar.
Posted on Jan 19, 2009
    Master:
  • 416 Answers
Try to remove cartridge an place it back. Also check the front and side doors and paper try. It sounds like it stuck on self-test mode
Good Luck
    President:
  • 1,990 Answers
Welcome to Fixya! OK, People it WORKED FINE Before. There is no problem with the Power Cord! Have you tried this, Unplug all the Cables and Power from the Printer, Uninstall and Reinstall you software, Restart your PC, Connect the Cables and Power Back. Run Setup on the PC Printer Software and Print a Test Page. Let me know so that we can get this Fixed for Ya!
  • 565 Answers
Try This Link - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=441125
If it doesnt help then its possible that your power input is demaged. Thsi u can repair in nearest HP service provider.
If it helped rate fixya
    Sergeant:
  • 367 Answers
Have you tried different electrical outlet. I have seen outlets fail (rare but has happened). If it is plugged into ups or surge strip try directly plugging into known working outlet.
Let me know if this fixes issue, If not I will ts further
  • Rob Houg
    Rob Houg Jan 19, 2009
    Did you check the spot where your plugging it in. If the outlet is not outputting enough then this could be your result. Try different outlet. Not different spot in ups or surge. Try different outlet possibly different room if same issue remains at different wall outlet then troubleshoot further.
    Let me know
  • 679 Answers
Solution one: Reset the productUse the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Posted on Jan 12, 2009
  • rockfixya
    rockfixya Jan 13, 2009
    did you tryed a reset method.
    Thanks for using FixYa.
  • 10,515 Answers
Reset the printer..
Some HP machines have 3 reset levels.
I do not know if the 5610 had them but it's worth a try.
Power off printer, then press and hold buttons while powering on, if it doesnn't reset, then unplug it and press and hold buttons while plugging it in, please tell us if the machine even tries to reset.
# and 3 Partial Reset
# and 6 Semi-Full Reset
# and 9 Full Reset
A Full Reset will clear any stored information in the printer, speed dials, etc, so always start with a partial reset and work your way up.
The following link wld also helps u :)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&lc=en&cc=us&dlc=en&product=441125&rule=46021&lang=en
Thanks.
  • HP Master
  • 13,433 Answers
Hold down the power button for 30 seconds if it doesn't work on, unplug replug wiggle the connector try again.
if that doesn't work:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord. Continue holding until it displays Semi Full Reset message in the front panel of the All in one
See if the issue is resolved.
    Genius:
  • 1,550 Answers
You need to try with different power cable. It is due to faulty power cable.
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
What can I do for a c 31:30
The C:31:30 error message displays on the Camera screen when it requires a power reset. Try performing the Power reset of the Camcorderby turning off the Camcorder and removing the battery and AC Adaptor from the Power. Then, wait for 60 seconds and reinsert the battery or the AC Adaptor. More resolutions can be provided with the exact model of the unit.
This should resolve the issue.
Thanks for using Fixya
Jan 18, 2011 | Cameras
What is the DC voltage needed for AT&T 1717
The AT&T 1717 requires 9 Volts _ AC.
Too bad some solutions are provided with inproper information.
I have a 1717 and just replaced the AC adaptor so I speak with experience.
Feb 22, 2010 | AT&T 1717 Digital Answering Machine
My computer is plugged in, the battery is installed but when I push the power button to turn it on nothing happens. Is there some other way to turn it on?
The way you're trying to turn on the Computer is correct but the issue may be related to the Hardware and service may be required. However, you may try some troubleshooting steps to determine if the Computer requires to be serviced.
Remove the Battery from the Computer and disconnect the AC Adaptor then press and hold the power button on the Computer for 30 seconds. Then, connect only the AC Adaptor to the Computer and try to turn it ON. If the issue persists then the Computer requires service.
Dec 01, 2009 | Dell Latitude D610 Notebook
My compaq pc wont turn on what can i do to fix problem?
Disconnect the AC Adaptor and remove the Battery. Then, remove the RAM modules, clean the RAM slots then reinsert the RAM into it. Next, press and hold the power button for 30 seconds. Now, connect only the AC adaptor to the Computer and try to turn it ON.
If the Computer doesn't turn ON then the problem is related to power supply and it's required to get the Computer serviced.
Nov 30, 2009 | Compaq Computers & Internet
Powering on the laptop
Remove the Battery from the Notebook and disconnect the AC Adaptor. Press and hold the Power button on the Notebook for 30 seconds.
Connect the AC Adaptor to the Noteobook and to a different wall outlet then press the power button to turn ON the Notebook. If not then insert the Battery pack in the Battery compartment of the computer then press the power button to turn it ON. Make sure that the Battery is fully or optimally charged.
If performing the above mentioned steps didn't power up the notebook nor the power indicator glows on the notebook then the issue is with the power circuit and service will be required.
In this case, contact any service technician to get the Notebook repaired and running.
Nov 03, 2009 | Acer Extensa EX4420-5239 Notebook
Hi, there i own dell latitude d620 when i press the power button it appear led power light and not boot, and it off itself why is this? please help me....
Remove the Battery then clean the metal contacts on the Battery and in the battery compartment then press and hold the power button on the Computer for 30 seconds.
Next, reinsert the Battery and try to turn ON the Computer. If the Computer keeps turning off then connect the AC adaptor to the Computer then try to turn it ON.
If the Computer keeps turning off automatically even when the AC adaptor is connected to it then the issue is with the power supply unit and requires to be replaced.
Oct 24, 2009 | Dell Computers & Internet
Changara
Try turning on the system without the AC adaptor. If it doesn't work on battery, then try pressing and holding the power key (after removing the battery) for 30 seconds.
Now attach the AC adaptor and try to power on.
If it doesn't work, it sounds like either a motherboard issue or an AC adaptor issue (possibly there isn't enough voltage being supplied) but it's an odd problem. I hope I helped.
Stay spicy, and happy lappying! :)
Dec 16, 2008 | IBM ThinkPad A22e 2655 Notebook
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Nov 01, 2007 | Audio Players & Recorders
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
