Question about Iomega StorCenter ix2 1000 GB Network Storage Server
Ix2 flashing red light - Iomega StorCenter ix2 1000 GB Network Storage Server
2 Suggested Answers
mileso
  • 3320 Answers
SOURCE: red light blinking
One of the hard drives has failed. Replace it.
Posted on Apr 09, 2014
Red light blinking
Apr 08, 2014 | Iomega Storcenter Ix2-200 2 Tb Network...
Red light is fashing iomega storcenter ix2
I am having the same problem. Once I start the storcenter, blue light start flashing and then in a minute or so it changes to red light. The solutions posted earlier are not clear.
Sep 07, 2012 | Iomega StorCenter Computers & Internet
I have the Iomega ix2 2T iCloud edition and forgot my admin password. How do I access it? (even if I have to reset everything)
At the back of the drvice there is a little reset swtich, located just above the rear usb port. Take a small object (eg. a paperclip) and press the button for 4 seconds. This should reset the password and disable the security.
Aug 13, 2011 | Iomega StorCenter ix2 1000 GB Network...
I have just bought an Iomega Strocenter iX2 but cannot get it to work. I get two white lights on the front panel to show up permanently and from time to time a blue light. The set up software just says...
The IX2 doesn't have white indicator lights. The IX2-200 does which would mean that the device is healthy and ready for use.
Since you are directly connecting it to your imac via ethernet cable which is the only way to connect to the device as the USB's are hubs.
First make sure you computer is getting an APIPA address 169.254.x.x (x represents randomly generated numbers by the computer), do a factory reset (depressing the reset button on the back for 4-5 seconds) which should restart the device, open a Terminal window (Applications -> Utilities -> Terminal) and type (without the quote marks) findsmb and hit enter. You should see your device populated on that list and you should also see an IP address associated with the device. Open an internet browser window and type the devices IP address into the address bar without the "http://" in front. You should have access to the device now.
At this point you will want to statically (manually) setup an IP for your device with your networks subnet. Once you statically set the IP. Disconnect it from your computer and put it on the network.
Good Luck.
Dec 18, 2010 | Iomega StorCenter ix2 1000 GB Network...
I forgot my admin name and password for my iomega ix2
is there any data loss, if i reset the switch on backside.
Oct 10, 2010 | Iomega StorCenter ix2 1000 GB Network...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
I have an iomega ix2 store center and yesterday i lost connection to it. i tried rebooting but after the flashing blue light goes away the red light comes on and i cannot connect.
Kate,
What you must do is that firstly, disconnect the printer from the PC. Then go to Start->Control Panel->Add Remove Programs. Select this printer and uninstall it. Reboot. Insert the driver disk into the drive and install the drivers again. Reboot. Now attach the printer to the PC and allow Windows to detect the printer and load its drivers and give you a message in the right bottom corner of the screen "The new HW is installed and is ready for use". Now it will not give any problems. Also read the following link for complete procedure.
Happy Holidays
Installing Devices on PCs and Laptops
Dec 22, 2009 | Office Equipment & Supplies
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Iomega StorCenter ix2  1000 GB Network Storage Server Logo
276 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
