Question about Samsung RF266AEPN
Samsung RF266AEPN BUZZING NOISE and back Panel Iced
Details: One year into this refrigerator. The fridge begins to make a semi loud buzzing noise and notice the back panel had iced. It sounded like the fan area was hitting the ice when turning which caused the noise. By researching this model I have found this model has problems with this area. The fix would be to replace the therminster and control board a cost of 399.00 labor and parts. Year warranty expired and problem began 2 months after expiration. Is this a mfg. defect?
  • Samsung Master
  • 2,598 Answers
Sometimes they ice up because the defrost cycle does not work, check for a faulty fuse, in the circuit board.
Posted on Jun 04, 2017
4 Suggested Answers
  • 700 Answers
SOURCE: Samsung RF267AABP Noise problem
it sounds like the unit is in defrost. the noise is the souind of the ice breaking up. also you might be able to increase your ice produsction by setting the ice sensor to 17.5 degrees from the current 0 degrees
Posted on Mar 06, 2009
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
SOURCE: Freezer side tmp flashes/makes noise/inside back panel iced
The freezer side is off. The temp is flashing on the meter in front of the refrigerator. This is a Samsung RS2545SH. Does this freezer have a reset button or what shall I do.
Posted on Feb 01, 2010
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
Sep 26, 2016 | Frigidaire Refrigerators
Have an LG fridge about 10 years old... makes a loud buzzing noise occasionally. Fridge seem to be running fine.. Thoughts??
Dear Sir
I think this abnormal buzzing sound coming from you
Compressor inside thats creating the buzzi sounds its normal. After a long time used it can possible. Neednt to worry
Hope answer the question
Jul 19, 2016 | LG Refrigerators
Is it buzzing from the compressor?
Dec 06, 2012 | Samsung RF266AEPN
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Fridge freezer making a loud buzzing noise
My Samsung refrigerator (rf263aebp) was making an awful buzzing noise in the rear after only 1 year. I solved the problem by loosening the rear panel that covers the fan. Apparently, it was too tight and was rubbing on something (the fan?) and causing the noise.
May 24, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have an american style fridge freezer from Samsung and it is buzzing when the fridge door is shut. I am guessing there is an ice build up around the fan but cant get the cover off easily. Any ideas...
i had a fan noise and the repair tech replaced the fan...turns out that the new fan was also making noise which lead me to look for other problems which lead to the fan problem
new fan was also buzzing in my freezer after some time...noticed ice build up towards the bottom right corner of the back panel (in freezer)....i diconnected power...took the back panel off had frost on it....coil was iced up.... then on the back of the refrigerator i accessed the control board....plugged the power back on ...i jumped the line to the heater...heater didnt work....then checked resistance through the heater (checked ok)....
it came down to me replacing the defrost thermostat which is in series with the heater....defrost now works fine ...which is every 60hrs for 45 minutes on mine.
good luck
Oct 02, 2009 | Samsung Refrigerators
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Samsung RF266AEPN Logo
100 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
