Question about Dyson Vacuums
How to clean dyson cyclone rotor 8 filter - Dyson Vacuums
Agent Don
  • 310 Answers
SOURCE: My dyson cyclone assembly will not spin when it picks up dirt.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=34171&thid=680773
My dyson cyclone assembly will not spin when it...
Posted by littleladysc on Jun 18, 2008
I have 2 dyson dc07. The cyclone assembly will not spin when dirt is picked up, but when I change them out the vacuum is fine, so I know it is the cyclone assembly. Any suggestions? Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dyson DC07 Bagless Upright Cyclonic Vacuum.
It sounds to me that you may have a clog but when you said you changed them out the vacuum is fine, so a couple of things, if the vacuum is still under a factory warranty of 1 or 2 years the cyclone assm still would be under a factory warranty. If it is over the 1 or 2 years then you would have to replace the cyclone assm but you may want to check with the Dyson Factory Tech Support / customer Service line as per the problem, and they can ship you the part from the factory or to check with your local vacuum cleaner dealer in your area and they may have one in stock or they can order one for you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/
Dyson Inc. 600 W. Chicago Suite 275 Chicago, Illinois 60610
Customer Service 1-866-693-9766 questions@dyson.com
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 18, 2008
SOURCE: dyson blowing top of cyclone air release valve.
It sounds like the same problem I was having. I had loss of suction through he hose then all of the air was coming out through the vent/valve on top of canister. If you are looking at your dyson from the back, look at the bottom. You will see a purple plastic tab on the bottom left. That allows you to remove the plastic u-shaped hose that goes from the hose to the bottom of the dyson. I just removed that and found it was completley blocked. I removed it and the dyson has no loss of suction orair through top valve/vent. I hope this helps. I never post but i'm just excited that I got my dyson working perfectly again.
Posted on Jul 11, 2008
  • 25 Answers
SOURCE: Dyson DC 17
yes clean with a jet wash
Posted on Sep 05, 2008
  • 4 Answers
SOURCE: How do I dmantle the Cyclone?
You don't! It is not meant to be dismantled. Just pour water inside it. Then let it dry out thoroughly, say, 3 to 4 days, including the filter.
Posted on May 30, 2009
promo7uk
  • 19 Answers
SOURCE: how do i clean my dyson root cyclone vacuum
believe it or not i would use a long paint brush with a opened bin linner,, to collect all the dust,,,
you can wash your blue filter in plain water and leave to dry as u would pots n pans on the side,,
when u have cleaned the area around the cyclone.. close your eyes and blow into the cyclone.. then use another large hoover to remove access dust and rubbish that was in the cyclone,
hope this helps reguards lee.
Posted on Jun 26, 2010
Dyson dc18 smells like dirty dog
I would clean the filter and let it dry completely for 24 hours. if you put the filter in wet and the run the vacuum the moisture well go in to the cyclone and the dirt would attach to it causing a snowball effect if you will, causing the vacuum to build up with debris and to smell. so clean out that filter really well and let it dry really well then try it out. if it still smells then i would replace the cyclone. they run anywhere around $80.
Jul 17, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The bagless rotor does not rotate/sweeper does not rotate
There is no rotor inside the clear container that turns on a DC07. The stuff spins due to the shape of the airflow. Perhaps your cyclones are completely clogged. you can clean them yourself. see this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Jul 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you clean the Dyson dco7 cyclone top
Hi its Darran at Dyson.
We would not recommend that you take the cyclone top apart. This part is designed to be a sealed unit and taking it apart may affect ther performance of your machine ongoing.
If you are concerned with the performance of your machine, please follow the blockage procedure and filter washing instructions on our website in the support section at www.dyson.com or check your user guide.
If you do want to clear dust and debris from the cyclone, we recommend that you simply hold the cyclone top over a bin and bang the sides gently to remove any dust from the inside.
Kind regards
Darran
Dyson Customer Service
Mar 16, 2010 | Dyson DC07 All Floors Bagless Upright...
Whats proper cleaning maintenance for the dyson Dc07 animal
use water cleaning Hose Assy and Wand Assy and Pre-filter Assy and cleaning Cyclone Assy
Nov 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Animal vac gets dog hair in the HEPSA filter,
no id try call Dyson
Customer Service - 866-693-9766
Nov 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Why is my dyson turning off after 8 minutes using it?
It's overheating, almost certainly because there's a blockage somewhere. Dysons run quite hot anyway, so it doesn't take much of an obstruction to cause this problem. It may simply be that the filters need cleaning or changing. Follow instructions in your operator's manual for checking for blockages (can download from Dyson website if you've lost the original).
Oct 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cyclone not cycloning.
Vortex will require cleaning.
Try this site for help. http://dysonmanuals.llc.nu/
Jan 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
16 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
