Question about Sanyo Televison & Video
Small picture Picture is about 3/4 off the normal width
    Top Expert:
  • Sanyo Master
  • 14,553 Answers
If a standard set and not a LCD etc it has a picture tube, width is a product of the high voltage circuit in that set---this is called the deflection circuit----deflects the picture top to bottom and also left to right, most likely a bad cap or if a wave like motion can be seen in the picture maybe power supply but that is rare.
Not knowing the age, size or value of the set if it is over 5 years old or the screen size is under 32 inches just replace it.
If no major part is bad the repair could exceed 100 dollars.
Posted on Dec 06, 2012
Ho do I stretch the width of pincture
See the picture settings. If it is not selected as normal, this kind of fault can occur. Select this settings properly. Refer its user manual for details. http://electronicshelponline.blogspot.com/
Oct 18, 2016 | Televison & Video
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture adjustment on a samsung ue40f8000
Hi
You cannot choose individual width and height but in Tools > Picture Size you will find Auto Wide, 16:9, Wide Zoom, Zoom and 4:3
Hope this helps
Nov 07, 2013 | Samsung Cameras
Hdmi problems
It seems that the width of the displayed picture is less than normal. Change the aspect ratio to 4:3, and check. Go to picture setting menu to adjust the aspect ratio. Check its user manual for more details.
May 31, 2013 | Televison & Video
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
The width of picture is to wide
Not sure if you are using a CRT or LCD.
If CRT :
- The picture tube has gone weak. Get a technician to check it and change the LOT unit if required.
If LCD :
- See if your TV's remote has any Picture mode controls. Set it to 1:1 or see if you can set something called "Aspect Ratio" though the OSD. Set aspect ratio to 4:3 and everything should look normal.
Mar 05, 2011 | Samsung Televison & Video
Input from the TV or a DVD in standard width is automatically expanded to fill the wide screen. I would like to disable this feathure so that the picture is not distorted.
you need to find the picture format setting on the tv and set this to AUTO so that when the transmitted picture is 4:3 or standard it will show the 2 black/blue blocks down each side of the screen.
depending on IF your tv has this option. normally pressing menu will give you a picture option or some times there is a single button press on the remote.for example the sony tv is normally the blue "teletext" button.
Jan 17, 2011 | Televison & Video
Sany bravia have to big widh of picture
use the Remote and select MOD...picture and adjust to normal rather than wide screen
Aug 24, 2009 | Televison & Video
Picture problems
if it's Narrow on both sides, height and width vary with scenes
try replacing C4407, CR4403
Jan 02, 2008 | RCA P46921 46" Rear Projection Television
1998 27' magnavox tv/combo
Frame width is normal means. Check aspect ratio is changed in menu options. Even width is also enlargement means there is high output from power supply section. Check and change the high voltage filter capacitor.
Sep 09, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
