Question about Health & Beauty
I need circuit diagram for a TGA Superlight
It would seem that the electrics are all mixed up and I would like to check everything out.
  • 4 more comments
  • John Cassidy Dec 08, 2012
    The scooter is not showing any electric life and the charger is not charging correctly. Despite being on charge for two days the voltage has not risen in the batteries
  • John Cassidy Dec 10, 2012
    Thank you Robin. I checked and there are no fuses on this model, however your advice got me thinking. I borrowed a battery charger and charged the batteries individually and when they are back on the scooter I am getting a voltage reading of !2.4v. .
    Further to getting a voltage reading of 12.4v I have checked the current as far as the motor and am getting a 12.4v reading but nothing is showing on the battery indicater on the scooter and none of the instruments work. I am going round in circles (not on the scooter) Thanks again Robin.
  • Robin Hill
    Robin Hill Dec 10, 2012
    okay you need to remove the cover over the front handle bar it nromally riveted so you may have to drill them out, but removing the cover you will expose the controller etc, here you see the wires come up from the batteries, check here for a voltage, regards
  • Robin Hill
    also pull back the left and right handle grips and you will be able to remove the plaster around the lights, chec kthe wiring here
  • Robin Hill
    not plaster , plastic , sorry about that
  • 1,263 Answers
Okay /are you sure that one of the fuses located under the scooter is okay not all models have these fitted ..
Posted on Dec 09, 2012
Testimonial: "A really good help. It got me thinking."
How do i fix the choking on my 2008 Keeway Superlight?
If you put the choke on does it get better or worse,and have you checked the valve clearances are right.
Feb 22, 2015 | 2008 Keeway Superlight 125
Where can I find a handbook for a TGA Superlight front wheel drive
hi, there are two types one is the superlight and the opther is called the buddy,,
http://cdn.metricmarketing.ca/www.scootaround.com/files/manuals/evrider/EV%20Rider%20Super%20Light%203.pdf
I have repaired many of these and the biggest weak spot is where the battery cable fits into the front steer column...
Regards
Rob
www.gewizrepairs.co.uk
Dec 29, 2014 | Health & Beauty
Ajusting tickover on keeway superlight 125
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Keeway Superlight 125 carb issue
Keeway Superlight 125cc 2008 After riding for while difficult to put...
RM 125 IDLE ADJUSTMENT
PDF Moto Manual
Apr 23, 2014 | 2007 Keeway Superlight 125
Interior lights, gauges, door locks etc not working.
What kind of manual do you have ? Haynes or chilton manual ? these are no good , they don't show everything ! If you want one that shows everything . Go to ALLDATAdiy com Leading Source of Factory Automotive Repair Information
Checking power an grounds to the affected circuits would be the place to start . Using a wiring diagram to locate points in the circuit to test using a DVOM - digital volt ohm meter .
Looking at a wiring diagram i see that the lights an the power door locks master switch share a common ground - G- 200 could be a loose connection . Look at alldata would show location of this ground point as well as any other ground on the vehicle . Plus gives description of how all the systems on the vehicle work .
Do you know what voltage drope testing is ? Do you how to do automotive electrical testing ?
Electric Testing Techniques You Need to Know
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
May 19, 2017 | 1995 Ford Crown Victoria
We have lost the instruction manual for a TGA mobility scooter. The numbers on the scooter are 991186017 and also, AFIKIM Electric Vehicle.
If you contact TGA 01787 882244 they would be able to provide you with a manual, it is chargable though.
Jul 15, 2010 | Health & Beauty
I Have a Keeway Supershadow 250, after storing it for the winter, without any preping, the bike wouldn't start, so i jump started it from my car left it run for about an hour but then it just cut out with...
I had the same problem... (what i did is)
- take out the battery,
- clean the dust & dirt from the top of battery
- remove the plastic which seals the battery (yes, the one clearly marked "DO NOT OPEN") but do pay attention not to damage it.
- replenish with distilled water
- charge and after charge check whether the level of distilled water is OK
- put back the plastic seal and close it firmly
mount it .. and have fun ..
Jun 07, 2009 | 2008 Keeway Superlight 125 II
Keeway superlight 125 adjusments
Pull the slide out of the carb then move the clip on the jet needle down one or two notches. This will richen the low range fuel mix. You can also get a rear sprocket with about 4 more teeth. This will get you off the line and out of the corners faster BUT it will also lower your top speed.
Please rate this solution. Thanks supergunner!
Apr 17, 2009 | 2008 Keeway Superlight 125 II
Health & Beauty Logo
205 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
