Question about Hunter Ceiling Fan Light Remote Control
I have a Hunter fan/light with remote & the light & fan comes on whenever it want to. I can turn them on and off with the remote but sometimes the fan &/or light will come on by themselves
The model # of the remote is 27227
    Genius:
  • Hunter Master
  • 1,617 Answers
Change the codes in your remte receiver & transmitter. Your neighbor probably has a remotr fan with the same codes.
Posted on Jan 26, 2013
SOURCE: Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Posted on Jul 03, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: Hunter 52" ceiling fan model 23457-380, the remote lights up
check the hard wiring from the factory. Where the light kit attaches to the fan check the wires in the factory cubes to make sure none are coming off. I had a similar problem that kicked my **** for a few minutes but I saw a loose wire after a bit of research. My fan also clicked but never turned on. Also pull the chains on the fan/light to make sure they are on. Hope something works for you.
Posted on Aug 21, 2009
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
SOURCE: Hunter Fan problem
Thge black boxes are capacitors. One is a single and the other is a dual. Evidently the dual runs the two lower speeds and the single run the high speed.
You can test capacitors for basic operation with an analog voltmeter set to Ohms (Rx1 setting is best) by charging up the capacitor with the leadshooked up in one direction, and then reversing them to watch for the slight jump as the capacitor discharges back into the meter... note that this test only works with an analog meter and it must be set to ohms.
This is only a basic test for capacitors and will not indicate if it's withing specs, only that it basically works.
IMO, Hunter is known for having bad capacitors. I've just purchased two fans and already had to swap out the light kits, which contains the capacitors and switches, in one becuse of poor operation and excessive humming noise. since the other fans has the same componenets, other than being a different color, I also thought to try the light kit/capacitor assembly in the fan I've already installed before also installing the second fan.
Guess what, the other set of electircal components with the capacitors runs the fan slower and hums louder.
According to Hunter's web site, humming is a sign of poor engineering in ceiling fans (meaning a power hum rather than a hum from loose components) I agree and Lowes is about to get two Hunter fans back as my three cheapo fans that came with my house do not hum and also the one in my old house did not hum and moved more air.
Even the better capacitor set that I switched out still hums to some degree, so I'm climing Hunter's using **** components, probably becuse their chinese suppliers are screwing them and they're not bothering to keep up the quality control.
Posted on Jun 08, 2010
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
My hunter fan light can't be turned on/off with the light switch
The switch will only turn the power on to the fan/light. You have to use the remote to dimm the light & change the speeds. You should be able to install it on the wall next to the switch so you can turn on your light when entering the room.
I dropped my remote and now it won't work. I changed the battery, didn't' work. I bought a universal Hunter Remote that the guys at Lowe's told me would work, didn't work. I called Hunter, she said I...
There should be a series of little jumper switches (usually 4 white I think) inside the remote that should match the fan. sometimes you can get to from the battery cover, sometimes you have to unscrew the remote case. The instructions should mention this. Not sure if the fan itself has switches, or just hard set. Either way that's only 16 combinations to try.
Sep 20, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Nov 13, 2007 | Dryers
Dryers Logo
338 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
