Question about Stanley Measuring Tools & Sensors
Stanley 20 ft. tape refill - Stanley Measuring Tools & Sensors
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: I have a Stanley 12 ft. Powerlock tape model #
No. You'll have to replace the tape measure, or find another similar model to rob the part from...See here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 30, 2009
SOURCE: how to fix a stanley power-lock 25 ft measuring tape
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
Posted on Oct 17, 2009
  • 225 Answers
SOURCE: i have a Stanley Powerlock 25 ft. tape that broken
those are garuanteed for life,as long as it was product defect.I take mine to local hardware store for replacement.Been 5 yrs. since I bought one.
Posted on Feb 14, 2010
I have a Stanley Powerlock 25 ft. tape that broken at the 6 ft, mark where do i do to get if fix
Feb 10, 2010 | Measuring Tools & Sensors
Tape measure wont retract
check coil spring inside might be broken or disengage to the tape measure.
Nov 29, 2009 | Stanley 100 ft. Tape Measure, FatMax
Install tape
Pull it all the way out ... have a nail ready to put into the hole just past the end on the tape, in the spring. Remove the tape. Install the new one (insert the tang into the hole and twist). Remove the nail and carefully allow the spring to pull the new tape in.
I hope this works for you
Oct 17, 2009 | ACE Stanley& Pocket Powerlock Tape Rule
Looking for a replacement tape. Mine is broke. Can I buy just the inside guts?
you should be able to ----- how far to your nearest toolking store? you can still deal with them no matter where you are ---I deal with them all the time ,and I`m in australia
Sep 04, 2009 | Stanley 100 ft. Tape Measure, FatMax
I have a Stanley 12 ft. Powerlock tape model # 33-212. The plastic thumb locking trigger just broke. Can I purchase a new one and if so where?
Jul 21, 2009 | Stanley Tools/Goldblatt Tool No.30 - 506...
Fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
Mar 11, 2009 | Grip On Tools Stanley& Fat Max Tape...
Adress needed
United States
Canada
Stanley Tools
1000 Stanley Drive
Concord, NC 28027
Attn: Quality Assurance
Stanley Canada
1170 Invicta Drive
Oakville, Ontario L6H 6G1
Feb 23, 2009 | Farberware Stanley Power Return Tape...
Need info on teturning tapes under warrenty
stanley tapes are life time warranty take it back where you bought it they should replace it.
How to basically operate my stanley fatmax, TLM100. The directions that came with it were for another Stanley product. Thanks,Ralph
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Nov 16, 2008 | Stanley 100 ft. Tape Measure, FatMax
Measuring Tools & Sensors Logo
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
