Question about Dryers
Do i light my pilot - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 07, 2012
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
My pilot light is out and I don't know how to light it please help
Most gas heating appliances have a knob on the gas valve marked on - off and pilot. Turn the knob to pilot this should allow the knob to be depressed which will allow gas to flow to the pilot. Some units also have a peizo ignitor which is a button that when pushed creates a spark to light the pilot this button must be push several times to light the pilot. If there is no peizo ignitor a lighter or match must be used to light the pilot. A fireplace lighter is best for this because the flame needs to be close to the pilot to light it. Have the flame source at the pilot before you depress the pilot knob to avoid a build up of gas which can be dangerous. Make sure to follow all instructions on the unit. Hope this helps
Dec 23, 2013 | Heating & Cooling
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
Pilot light won't light the low flame or stay on
If the pilot light will light at all but not have a good strong flame I would remove pilot assembly and clean it thourghly,being careful not to damage pilot orifice. Reinstall pilot and seeif you have any improvement. If pilot still won't stay lit I would replace thermocouple being careful to make sure top inch or so is in pilot flame. Hope this helps. Thanks
Nov 20, 2010 | Blue Rhino Heating & Cooling
Trying to hook up a pilot light switch to a gfi recp not having much luck with getting it to work properly i got 2 conductors from the panel and 2 conductors going to the gfi recp and on the switch i have...
It is unclear what pilot-light-switch is supposed to turn on-and-off.
Option A) pilot-light-switch is going to turn GFCI on-and-off
Option B) pilot-light-switch is getting power from existing GFCI circuit, and switch controls another Load (light, fan or motor) located elsewhere.
Add a comment at any point.
Bare copper wire always connects to green screw.
1) I have a Cooper pilot-light-switch in my office.
Black Hot wire from breaker always connects to dark-colored screw(s).
White Neutral wire from breaker box connects to silver-colored screw
Wire going to Load (light, fan, motor) connects to brass colored screw.
2) Two things happen when pilot-light-switch turns ON:
a) Pilot light turns on. This circuit is powered by black Hot wire, and circuit is complete with white Neutral.
b) Brass screw that had no power, is now powered.
The GFCI:
Hot from breaker always connects to brass-colored Line screw
Neutral from breaker connects to silver-colored screw that is opposite Line screw.
If other switches and plugs are going to be protected by GFCI, they connect to brass Load screw and to silver screw that is opposite Load screw
Option A) You want pilot-light-switch to turn on GFCI receptacle.
a) Wire pilot-light-switch as described above
b) Black wire from GFCI line-screw connects to brass screw on pilot-light-switch.
c) White wire from GFCI silver-screw-opposite-line-screw connects to any white Neutral.
Option B) Pilot-light-switch is getting power from GFCI receptacle AND you want pilot light switch protected by GFCI.
a) Black wire on pilot-light dark screw connects to Load screw on GFCI
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw
Option C) same as option B except pilot-light-switch is NOT protected by GFCI.
a) Black wire on pilot-light dark screw connects to Line screw on GFCI or any Hot wire
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw or to any Neutral wire
Nov 19, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
We have an older (22 years?) 'Insta-Flame (model HE30 TN) natural gas fireplace insert. The pilot light is out, as we painted to inside of the firebox. The instructions show to 1) turn the dial to 'off'',...
On some gas valves the pilot setting is on the same dial as pilot on and on .on others the pilot light has aseperate button on right side of control dial. If yours has this there will be a cut out on cotrol dial that must be aligned with button to allow it to be depressed to light pilot. If yours has this align control dial cutout with pilot button,depress button and light pilot,hold for about one min. and slowly release,if pilot light stays lit,turn down thermostat and rotate control dial normally to right . There should be arrows or marks on dial and gas valve to line up. If pilot light stays lit turn dial to next position and check to see that pilot is still lit. This should be on position, turn up thermostat and burner should light. If your dial has pilot light setting on it then rotate dial to each position,try to depress dial and when you have right one dial will depress allowing you to light pilot. Follow same procedure as above and you should be in business. Hope this helps.Thank you
Nov 11, 2010 | Heating & Cooling
Gas is on pilot won t light
Hello there: The problem you mention is not that clear. The pilot won't light or the pilot lighted but won't stay on is two different problems. If the pilot won't even light or no gas coming out off the pilot when you push down the pilot button it means the pilot orfice is blocked and what it need is cleaning the pilot orfice. If the pilot light is on but goes off when you release the button then the thermopile need to be changed. Hope this can help.
Sep 23, 2010 | Frymaster Dean Kitchen Appliances - Others
How do you light the pilot light
turn gas valve to pilot position, hold button continuously, light pilot gas at orifice, keep holding button down for 1 more minute as Thermo-coupling heats up. pilot should remain lite.
Oct 18, 2009 | Heating & Cooling
Dryers Logo
Top Dryers Experts
