Question about Zenith Televison & Video
Attach cable to a 1994 zenith tv - Zenith Televison & Video
    Top Expert:
  • Zenith Master
  • 14,553 Answers
It either has a cable fitting or two screws for this, the two screws require an adaptor called a matching transformer which has a cable fitting on one end and two wires on the other.
Posted on Dec 06, 2012
Can you hook up and play xbox through this combo zenith xbv343
Yes you will need component cable and you can attach your xbox to the front left of this combo. You will have to select the correct auxillary input once the xbox is connected so you are able to view on your tv.
Mar 03, 2011 | Zenith XBV343 DVD Player/VCR
Last night our Time Warner cable went down. The internet service returned but our 2004 27 inch Zenith TV will not turn on i.e. no picture or sound. The switch seems to activate as a click is heard and...
I think that the unit is going into protective shutdown because it has detected an internal problem. I would suggest that you invest in a detailed repair estimate that will cost about $100-$150 depending upon your location. It might cost even less, especially if you take it in. You could also contact Zenith and see what they might say about this problem first before taking it in.
Main support number 1-877-993-6484
Mar 27, 2008 | Televison & Video
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Aug 19, 2010 | Zenith Televison & Video
How to connect a 1999 zenith TV to a cable box and
Connet the output of the cable box to the DVD player and the TV out output of the DVD player to the TV (TV must be tuned to Channel 0, Chanel 3 or 4). You should be able to use the remote to switch between the DVD signal and the cable signal.
Hope it helps.
Sep 08, 2009 | Zenith A25A23W 25" TV
Is jack on Zenith TV #SR2571DT6 for component or composite video
the spec on any TV is easy to find and read, as is the whole manual. ever just google it and read it? oops it is relic,
the answer is composite that old.
the online book is so blurry i cant read the page on jacks.
the 1994 no PDF then only now we have horrid scanned pages.
like 30DPI horrid .
first off this is not HDMI, those are all inputs.
SR or SM? is that a typo, ? google finds zero on your model.
omg there are SR TVs made in 1994, wow that is one old TV.
quote wiki. (all are inputs,never outputs)
Most older TVs that have AV inputs will have a set of composite inputs as will as some HDTVs, but typically only HDTVs have the Component inputs. Check your TVs inputs to see what you need. If the input on the TV has only 3 connectors (yellow, white and red) it is composite and if there are 5 connectors in the input grouping together you need the component cable.
this is the SM model, only one I can find.
it clearly says INPUT, see?
and has 2 channels for say 2 VCR's LOL
this is composite due to component jacks not invented in 1994 yet.
sm-z1fpin1ha24aqwl2cxswhash-5-0.jpg not this
the source the RGB colors tell you its component class.
and for for sure the Y signal jack Green.
nor this.
i think 2008 is year of introduction never 1994,
component2-z1fpin1ha24aqwl2cxswhash-5-3.jpg note the 5 cables.
Jan 23, 2018 | Dell Ultrascan 20TX - 20" SVGA Monitor...
Zenith DVP615 backlight problem
Hi , for backlight
It DVD circuits will need to do servicing, as soldering , cleaning and should attach heat sink on the microprocessor, i guess.
May 16, 2008 | Zenith DVP615 Portable DVD Player
Need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Apr 27, 2008 | Zenith B27A11Z 27" TV
Broken cable connector
Yes, its not that difficult. You may even find that you can salvage the one that you have. You'll have to unplug the TV and remove the rear cover. The connector may be located in the rear cover or a plate that sticks through the rear cover.
The connector may be attached to the TV's motherboard or a sub-board. It may even be just a bulkhead connector with a cable that is bolted to a plate.
Let me know what kind of "F" connector it is and I'll help you locate a replacement. Maybe you'll be lucky and just have to resolder the old one.
- Jim
Jan 31, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
22 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
