When settling a batch, my terminal will say TCP error 1003003a and fails to settle my batch.
3 Suggested Answers
danielizapat
  • 88 Answers
SOURCE: We have the Verifone VX510.
call the verifone number on the machine try plugging it in to another phone line
Posted on Aug 04, 2010
  • 10 Answers
SOURCE: Our Verifone VX510 printed our
This problem could have multiple causes. It sounds like you are receiving a settlement error, which are specific to each merchant services provider. You will have to call the merchant services provider so that they can look up the error message on their end and tell you what is causing the error. For example, the error message that you would receive if you use First Data would be different than the message you would get if you used Bank of America. Your terminal will not let you run any more cards until you resolve the settlement error. This is to prevent you from continuing to run cards in a corrupted batch, or a duplicate batch.
Posted on Jul 29, 2011
How do I fix a Batch Erro QD-621-0108??
QD Error-basically is saying... quit duplicating. there is a transaction in the batch that is not allowing the batch to settle and it is failing, call your TSYS provider call center to have them look at the batch, either take out/ void- the transaction that is failing or causing the problem and then try to settle or have them force the batch thrueclear the data base and reset the batch number. This should fix the problem
Jan 09, 2015 | Retail Supplies
What does must settle TSYS MEAN WONT TAKE CARD
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Sep 19, 2014 | VeriFone VX510
How to fix settle error RB-000-E0001H18000 on a hypercom t7plus
that error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end too.
Sep 03, 2014 | Hypercom T7Plus Credit Card Machine
Why batch error RB-000-E0001H18000
That error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end ...
Batch out omni 3730
in order to settle or batch you will press the purple "more" key or the purple key to the far left until you see settle or close, then confirm amount. if you get a error message you will need to call your processor. if you get a QD followed by numbers or RB followed by numbers you need to call processor. if you take tips and have not adjusted them it will prevent from settling at times, check your sales by printing a report, press the purple key to the right of the alpha key above the 2. check your reports and try again. if you are getting can not connect to server or host, then you do not have a good phone or Ethernet connection. check those and reset the modem or terminal by unplugging and plugging back in right away. may need to leave unplugged for 60 seconds if it does not reboot it self.
if you lost the sales call processor.
Jul 29, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
Vx 570 auto settlementIf I manually settle my VeriFone credit card terminal in the morning, why doesn't it auto settle at the scheduled time that night?
Most likely because you settled the day in the morning and your processor only allows one batch settlement per day.
The type of terminal in this case doesn't matter. Hypercom, Ingenico, PAX, Verifone etc... It is all about what the processor allows in the programming.
May 19, 2014 | VeriFone Retail Supplies
Feeds paper out on its own without doing a transaction, usually on a weekend
it is trying to settle the batch, even if you are not open during that time. the terminal is programmed to run a settlement report each day- so it tries to settle funds that may be in the terminal. if no funds are in the terminal it will look like it feeds the paper with no reason.
Feb 10, 2014 | VeriFone Retail Supplies
The amex card not read by machine. it shows on the screen:- settlement failed...
ANY card swiped when machine returns settlement failed error will probably return the same error. It's not the card - it's the batch stuck inside the machine. Whether manual batch or autobatch, sometimes the data IS actually transferred completely out of the machine but somehow the machine doesn't get that message from the backend server that settlement was completed *settlement failed* , there may have been some corrupted files, or maybe the settlement really did fail and is stuck and needs to be settled/batched out/transmitted to free up that terminal. Try simply settling that machine - press the down arrow (far left purple function key) ; press F2 Settlement and follow prompts.
Mar 29, 2011 | VeriFone VX510
Nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
289 people viewed this question
jasbo
jasbo
