Question about Magic Chef Microwave Ovens
Where is the fuse in the fuse in the Magic Chef MCD11E3W and how do I replace it?
dmftrucker
  • 1922 Answers
SOURCE: fuse replacement of Magic Chef MCD990W
you'll need to completely remove outer cover its under the outer cover,be very careful inside even unplugged it can store 2000 volts on the capacitor for sometime
Posted on Jul 27, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The light is off on my Magic Chef MCD11E3W
Since the owner's manual doesn't cover it, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Posted on Nov 29, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: my magic chef micro does not work. I replaced the
In many brands, there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some questions to help you or someone you know troubleshoot it:
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
Posted on Dec 07, 2009
  • 6771 Answers
SOURCE: have a magic chef mco160uw microwave. Had a recent
No! there is no reset, the power surge has more than likely damaged the keypad controller, and on the back is a circuit board that has the microprocessor with additional components that controls the vital areas of the microwave oven. If that is gone, it is cheaper to replace than to repair.
Posted on Feb 06, 2011
Testimonial: "thanks for your info."
MicrowaveSvc
  • 9047 Answers
SOURCE: HOW TO REPLACE LIGHT BULB IN MAGIC CHEF MICROWAVE
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
You'll need to remove the outer cover (wrapper) to get to the bulb.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 18, 2011
My magic chef microwave died. I replaced fuse, and electrical works but won't cook. Why?
Most likely if the fuse blew the part that creates the microwave energy is defective, it is called the "Magnetron" Just replace the oven is my suggestion.
Nov 11, 2016 | Magic Chef Microwave Ovens
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Magic Chef Microwave Ovens
Magic chef microwave buttons will not work but microwave is on
its a connection problem probally from a bump while driving the camper - you can dismantle the microwave yourself from the back and reconnect the jared wiring, or just replace it with an industrial one that can handle the camper abuse.
Jan 04, 2014 | Magic Chef MCD990R Microwave Oven
No power to my Magic Chef over the stove microwave oven. Is there a fuse that can be replaced, and where if so?
There should be a fuse and one or more thermostats or thermal cutouts.
We would need your full model number.
Nov 30, 2011 | Magic Chef Microwave Ovens
HOW TO REPLACE LIGHT BULB IN MAGIC CHEF MICROWAVE MODEL MCD11E3W
Oct 14, 2011 | Magic Chef CMV1000B Microwave Oven
I have( had) A magic chef microwave model MCD11E3W I must have had a power surge in kitchen refrig and oven turned off circuit breaker turned off.. All other appliances came back on but the Microwave,,...
It ispossible that the secondary transformer has failed which is the feed of the voltage for the processor timer/clock unit. So check this out with a multimeter and you can get to buy the transformer as it is a step down low voltage type., normally mounted on the processor board.
Check also if the fuse has blown if so replace.
I dont think there could be any further damage.
Credit me if this helps.
Aug 26, 2010 | Magic Chef CMV1000B Microwave Oven
The light is off on my Magic Chef MCD11E3W Microwave Oven how do I replace it?
See these files:
Nov 28, 2009 | Magic Chef MCD1311ST Microwave Oven
Fuse replacement of Magic Chef MCD990W
Jul 13, 2009 | Magic Chef MCD990W Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
