Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
No fluid to floor
No solution to floor but works in hose
  • Official Brand Answer
  • 315 Answers
Here's a link to troubleshooting steps: http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Here's a link to assist you in locating one of our Authorized Service Centers if you still experience difficulty.
http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Dec 07, 2012
The hose is sucking up but the base plate doesnt?
If you have taken the bottom end of the machine apart, you might not have reassembled it correctly so that the path to the floor (base) plate is obstructed when the vacuum cleaner body is laid back, otherwise:
You have either a blockage in the section of the cleaner in the vicinity of the short flexible hose and the floor (base) plate or the the short flexible hose has become detached at one or both ends.
1. Stand the machine upright with the beater bar in the "off " position. Machine switched off but plugged into the mains outlet.
2. Lay machine on its left hand side. You will see the short flexible hose uppermost. Check that it is attached at both tends and has not split or cracked. Check for obvious visible obstruction inside.
3. Remove the floor (base) plate by releasing the three plastic clips with a quarter turn anti-clockwise. Lift floor plate forwards and check no obstruction. Replace floor plate. Stand machine upright on floor.
4. Press two plastic clips to release the inspection cover, on bottom right hand side of machine (when standing behind it). Look into the hole: you will now be looking down into the U-bend that leads to the hose. Switch on the machine: full suction should be at the hole on the side of the machine (otherwise the hose would not have worked). Switch off.
5. Lean the handle and machine body backwards, as though you were going to use the machine on the floor. The hole to the hose now becomes covered and you will be able to see into the short flexible hose that leads to the floor plate. Check for obstruction. Replace inspection cover.
If there's no obstruction and the flexible hose is sound and attached securely then the machine will work - there's nothing else to check.
Jul 10, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The hose is sucking up but the bottom doesnt...
Why have you posted this question twice on the same day?
Only suction from hose
What again for the third time? Already answered this but if it helps:
Jul 05, 2014 | Dyson Vacuums
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
Shark transformer vac model ep602 will not suction from the floor brush, but will suction from the flexible hose. Dust cup and filters are clean. Do I need to replace the floor brush? Unit was purchased...
Has the floor brush ever worked for you? I thought it was broken at first too. The hose has to be inserted in the appropriate hole in the side of the machine. The hose is where all the suction comes from, when you put it in the side hole it will provide suction for the floor brush.
Oct 11, 2010 | Vacuums
Blocked suction
Here is a tip that I wrote about my Bissel ... the hose should just pull out... it is just stuck in there tightly...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Royal 088500 Featherlite Upright Vacuum
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Bissell proheat 2x will not send out fluids in hose or floor area
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tulty
Feb 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dispensing problem w/attachment and maybe floor partion
The F5914 has a hose that must be attached to the pump when using the upholstry attachment. Make sure that the solution hose is pushed onto the pump valve all the way. Try pushing the hose down and then pushing the locking collar down to secure it. This will insure that the hose is fully engaged.
Jan 21, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Attachment problem
make sure everything is filled and secured tightly, if this a new unit it should be something simple ok, also check where machine folds down that the solution hose is not being pinched its right behind the dirty water tank
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
19 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
