Question about Dell Latitude D600 Notebook
My problem is that, IR on my notebook is not working. I need help to make it work.
Why wont the remote control feature work on my Panasonic TCP50UT50 Plasma, is there a feature to disable the remote, panel works well
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 21, 2015 | Panasonic Televison & Video
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
Remote Controll works inconsistently
Have you replaced the batteries in the remote with newones? If you have, you may have IR interference from some source in yourroom. It could be from a florescent lamp, another player, or even the TV. Isthe receiver in an open space or in an enclosed area? The IR sensor needs adirect line of sight to work properly. You may also check the receiver ifanything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Oct 27, 2009 | DISH Network IR Remote Control
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Error code 2A00:0430 Ir port not working properly
Hold F2 or Del (depending on your bios) to enter the bios config.  Turn off IR.
Apr 21, 2009 | Dell D610 PC Notebook
My labtop's IR didn't work, how can i reinstalling it?
Go into the BIOS utility. It depends on which manufacturer, but usually it's F1 or F2 or Delete , etc. when the laptop first powers up.
Look through the settings for an option to enable IR.
If you give the make/model I can give you more detailed instructions.
Jan 21, 2009 | Dell Latitude C400 Notebook
My Infrared on my dell D600 is not working. I need a driver to make it work.
Go into the Bios at boot up and confirm that the ir device is enabled, select a com port (port 2 is normal) and then boot windowws. XP should see the divice and install a generic driver automatically
Jan 08, 2009 | Dell Latitude D600 Notebook
IR detector
An infared detector is just a transistor that is covered with clear plastic.
matching the spec on it though is hit or miss.
first be sure it is not the ir trasmitter, take it to radio shack and see if their infared re-transmitter broadcaster sees it . or aim at a digital camera
or hold near a radio though that only hears the digital part.
radio shack has some iR transistors in stock usually .
basically you can just plug one in and it may work but you may have to know how to bias (balance ) the transistor to work correctly.
there are many places to scrounge a ir receiver transistor
old tvs , learning remotes, laptops , printers ,
you can inject the output signal of the remote into the ir circuit to see if it is working but you need to add a resistor and drop the voltage a bit.
hope that helps some.
Apr 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Using wmc ir keyboard with tablet pc
Acer's IR ports works only for Remote control and certain compitable devices only. its not open port for all devices. It cant be used for other pheripherals as far as i know! If its bluetooth then it can work surely.
Nov 25, 2007 | Computers & Internet
Dell Latitude D600 Notebook Logo
53 people viewed this question
Alun Cox
