The power cord on my JVC tv fell on the electric heater and made a big flash and now the tv won't work
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
To start with do not plug the set in again until it is examined.
If it melted the cord most likely if you are lucky the fuse inside the set is blown and at the least it and the cord in that case need to be replaced.
Posted on Dec 06, 2012
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: 32" TV fell over onto carpeted floor and won't
Good chance that it is if it broke the circuit tracks and cannot be reconnected,depends on how bad the board was damaged.
Posted on Jul 03, 2011
  • 148 Answers
SOURCE: JVC TV has flashing red
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Posted on Jul 18, 2011
Power timer light flashing, won't come on
Flashing of power LED are fault indications. You have to count the number of flashes occurs at one time. Check this link for more details about the blinking codes. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name first.
Dec 22, 2012 | JVC AV-32D305 32" TV
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
How do I find the power board in a 1997 big screen Sony TV to check the fuse? How do I check the fuse? I live in a house built in the 1890's, and last year there were 2 different tornados ,within 2...
With it unplugged remove the rear cover and follow the power cord inside the set to the power supply board===the cord goes directly to the line fuse which in a set of that age will be in a plug in holder----look to see if strand of metal in middle is broken or even blackened.
Amperage will be marked on end of such a fuse--my guess is 6.3 amps but there will also be a marking on the board with the value.
May 24, 2012 | Sony Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
Jul 18, 2011 | JVC AV-32230 32" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
