Question about Pentair Pac-Fab 2" DE Filter Multiport Valve 261152
I replaced a spider gasket on my PAC FAB 2# Multiport valve and when I put it back together the sequence is off. Filter mark is actually the waste port and waste is actually the Filter port.... how do you know if you are putting it back together correctly where the positions are accurate?
  • 372 Answers
There should be a screw hole in the valve lid that has a flat edge on one side (outside edge). The valve body has a matching flat edge that aligns with it.
In the event the handle was removed from the lid and diverter to replace the diverter o-rings it is not uncommon for people to put the handle back on the diverter 180 degrees of where it should be. The pointer on the handle should be aligned above the open port of the diverter. This is true of all multiport valves except the Hayward four way valve.
Posted on Dec 22, 2012
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I'm hearing air like sounds
Air only gets into the lines of your equipment if it enters somewhere on the suction side of the system. That means from the pump housing and strainer BACK to the pool on the inlets. Once the water passes from the impeller out the discharge of the pump it is under pressure and any leaks will result in water escaping from the line.
While your filter may or may not need work air is likely the result of failing gaskets or a seal in the pump. Replace the strainer lid ring, the pump body ring and the mechanical seal first. If there is still air look at the valve or valves in front of the pump for controlling inlet water flow...check for leaking stems or failing pipe joints.
John
Posted on Jul 21, 2011
Testimonial: "Replaced the gasket on the skimmer basket."
Both waste outlet and filter outlet emptying at same time. Turned filter and pump off. water still emptying through 'waste' line. Had to raise hose end higher than filter to stop flow. Any suggesti
bad multiport gasket you can get along by putting a ball valve on waste line or a plug in the pipe until you get another multiport gasket if you replace talk to who you buy it from some need to be cemented into place
Jul 14, 2014 | Pool & Spa
I have an AquaTools filter that is approximately 10 yrs old. I had a leak from the backwash. I replaced it with a Hayward spider gasket but the gasket seemed a bit small and water is still leaking out. ...
it's tight to turn because spider gasket is not correct size , if correct new old stock gasket cant be found then entire body of muliport valve needs to be replaced with modern equivelent
this will involve draining down water from entire filter section as glue needed to install doesnt like wet pipes too much and wont stick well leading to leaks , if your not 100%comfortable in doing this your self then a trusted pool service co needs be contacted ,plus who knows maybe they got the org gasket you need?
May 27, 2014 | Pentair Pac-Fab 2" DE Filter Multiport...
Pantera pool filter model p24
give them model number of filter and multiport you need new multiport gasket (spider gasket)
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Pac fab sp710 filter control (old)
yes new spider gasket careful you might have to glue it in
Sep 23, 2013 | Pentair Pac-Fab 2" DE Filter Multiport...
Where is the sight glass suppose to go
There is a port for it where the waste line is attached. It screws into the side of the valve body.
Jul 03, 2013 | Pentair Pac-Fab 2" DE Filter Multiport...
How to replace the gasket on a sm2-pp3 multiport valve assembly
make sure you note the position take a picture remove screws holding top of multiport on lift off there is the gasket clean off some have to be glued back on then put back together
Oct 06, 2012 | Pentair 112 Multiport Valve Kit for FNS...
How to replace the spider gasket
remove all screws from multiport make a mental note of position replace gasket and put back together
Apr 05, 2012 | Hayward SAND FILTER, PRO SERIES
I'm hearing air like sounds around the multiport valve. There's bubbles visible in the filter going to the pump. Bled the air on the filter itself and bubbles continues. Could the multi port...
John
Jul 21, 2011 | Pentair Kreepy Krauly Inground Automatic...
Hayward S180t filter w/ hayward sp 711 multiport valve. I removed to multiport valve to fix the spider gasket. I didn't think to mark so I could put the multiport valve back on. I need to know how to put...
Hayward 711A13 Vari flow valve. When I push down the handle to move valve into other settings the handle does not want to relock into the next setting. I have to manually pull up un the back of the handle and tap with my hand to get spring to retract. What can I do to lubricate this sping inside?
Apr 28, 2010 | Hayward SAND FILTER, PRO SERIES
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
Pentair Pac-Fab 2" DE Filter Multiport Valve 261152 Logo
296 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
