Desktop start up problem
My computer will not allow me to start up it turns on and then loops around 3 screens. I have my college work on it and cannot get to it can anyone help.I can see a message briefly saying Pri. Master Disc HDD S.M.A.R.T capability .... Disabled If anyone can help I would be eternally grateful.
  • Dan rogers
    Dan rogers May 11, 2010
    The message that it displays is just telling you that the hard drive's self diagnostic is turned off. When your computer is booting up can you hear any beeps?
  • 55 Answers
I would suggest that you get a copy of Ultimate boot cd or Hirens cd and run that if you can boot from cd. Then use the disk repair tools to help diagnose the problem. If you have anymore information that would help too.
Posted on Jan 12, 2009
What does it mean when phone is on desktop loop
Hi Shaundra,
A loop line or loop around is a telephone company test circuit. The circuit has two associated phone numbers. When one side of the loop is called (side A), the caller receives a test tone of approximately 1000 Hz(milliwatt test). When the second number (side B) is called, it produces dead silence, but the party on side A hears the milliwatt test tone drop, and is connected to the person on side B. The purpose of the loop around test is to allow circuit testing to a distant central office without needing a person at the far end. The technician can send a tone down either line and measure the response tone on the second line to determine the path loss parameters.
Sep 17, 2015 | Computers & Internet
Compaq cq1-1225 all-in-one desktop computer stuck in screen pattern loop at startup
Try a hardware reset.
Pull the battery out, unplug it from the adapter, and hold your finger on the power button for about a minute.
If you still can't get into the bios by pressing F10 of F2, i forget which one it is, try pulling ONE of the memory chips out.....try again....then the other memory chip and put the other one back in to eliminate any chance of faulty memory.
Good Luck!
Apr 08, 2014 | HP Computers & Internet
My aspire 5520 tries to turn it on, in kind of loop, without success. It keeps dark screen and there is no bios access available. The 'ON button' and the 'HD led', both keep 'on' for around 3 seconds,...
Hi, Every PC-Laptop has BIOS otherwise nothing would work at all. Try turning the PC on & hold down ALT & F4 together that should get you into the BIOS. As far as having no display then your Video card must be not working & needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 06, 2017 | Acer Aspire 5520-5156 Laptop
Dell Inspiron Desktop PC won't start up
Hit FN at boot then let me know what it does
Jan 14, 2010 | Dell Inspiron 530 Desktop Computer
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
May 14, 2009 | HP Pavilion dv5-1000us Notebook PC
Desktop screen won't stay on
how old is your screen, if its older than 2-3 years mostly its gone and you need to replace it. If its in warranty then contact dell customer support. Life of screen can be around 3 years after that i may not work.
Another test is to connect it to some other computer and see if its working, then we can focus on some output issue from the CPU.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Apple G5 Locked up
Sounds like you have a permissions issue, first boot in single-user mode and repair permissions.
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Jan 22, 2009 | Apple Power Mac G5 Desktop
Desktop problem
u have to on ur pc in safe mode by pressing F8 key u when u pwoer on ur system then press F8 continous pressing u will get option screen u have to select safe mode option then it will take time to on few minits when ur yu system on on in safe mode u have to do this click on start>program>system tools>system restore click on it
restoer your sytem prives week date if system not on in a safe mode then u need to format your system
Jan 12, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
