Question about RTO PasLode 900420 Impulse Framing Nailer
Where do you oil this airless nail gun
Where do you oil this nail gun, no hose inlet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Oil can be added through the back cap, remove your air filter first though....
Posted on Dec 09, 2012
2 Suggested Answers
  • 131 Answers
SOURCE: paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
Posted on Jun 23, 2009
My Dewalt framing gun blows compressed air thru the nailer nose? Thx Kurt
Rebuild gun with gasket repair kit.
How it works: Compressed air enters through air hose and fills gun cylinder.
When trigger is pulled, air inside cylinder rushes out and pushes firing pin that shoots nail.
Inside the gun there are gaskets that seal the nose, the trigger and the cylinder head.
When any of those three gaskets fail, then air starts leaking.
Putting a few drops of nail gun oil into gun before connecting hose is supposed to protect gaskets.
But everything wears out, and sometimes folks use 3-in-1 oil instead of gun oil.
3-in-1 is detergent type oil and will cause gaskets to fail.
Another thing is guns that are not used frequently and gaskets get dry.
Putting in a few drops of oil and then immediately shooting gun will cause gasket to fail, because gaskets are still dry.
Best to put in plenty of gun oil, and let oil go down into gun for a few hours before connecting hose and shooting. Even so, nail guns are designed to be used every few days with continual oiling.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Tools & Hardware - Others
My nail gun will not fire a nail. Do I need to oil it or something?
Hello, W/D here.
Here's a couple of things to do or check:
1. Put a couple of drops of a light oil in the nailer with the trigger depressed, and the gun disconnected from the hose. Set it to the side for now, with the air inlet facing up.
2. Check the compressor outlet pressures. The gauge nearest the tank is the air pressure on the tank. The gauge closest to to the hose is the tool supply pressure. Between the gauges id the regulator, where you can increase or decrease the pressure to the tool.
3. Check your required air pressure for your nailer, and make sure that your regulator is supplying at least that much to operate the nailer.
4. Connect the nailer to the hose, Spray the underside of the nailer head (the slide assembly where the nails are driven) and try to drive several nails into scrap wood.
5. If the nailer operates properly, all's well. If it still fails to operate, place a few more drops into the air inlet (while holding the trigger down) and wait a few minutes, then try the gun again.
There are other things that can be done, but oiling the nailer should get you going. BTW, you should oil the nailer before each use, and when you put it away.
Best regards, --W/D--
Jan 29, 2011 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
Airless does not have sucktion
diafram is stuck ( if gun is not new replace diafram on head )novice painters are known to not clean airless guns as well as they should and the diaframs all ways stick .....some times you can loosten it by removing the pick-up hose and inserting a blunt object inthe hole to loosen it ( dont push real hard or you will puncture diafram}
Jan 22, 2011 | Campbell Hausfeld Airless Spray Guns &...
Where on the unit are the inlet valve and the push button valve?
On the front of the pump unit is a large aluminum block, the valves are inside that. The inlet valve is behind the fitting for the suction tube and the push button valve is the only one on the bottom of the block.
Dec 17, 2010 | Campbell Hausfeld Airless Spray Guns &...
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
Nail gun will not shoot and air is exhausting out top vent all the time.
Oct 21, 2010 | Garden
Paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Can't find a part #
http://www.chpower.com/webapp/wcs/stores/servlet/chCat_10051_10001_10661_-1
service center, find a part. write inlet outlet valve
RTO PasLode 900420 Impulse Framing Nailer  Logo
59 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
