Question about Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 dual cassette deck
My tape deck will not play anything.the tape rolls but no sound.i tried to clean the heads but still no sound i have technics rs-tr272 dual tape deck.i ahve not played it in a while
  • Technics Master
  • 1,267 Answers
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Posted on Oct 17, 2012
My RS-TR272 tape deck plays the cassette but no sound. I have not even used it much, may be 3-4 times in last five years. I tried demagnetizing it but still no effect. It is brand new unit, only thing I did last time was that plugged in the RCA cables in opposite ways one time (Output in In and In into output one). I am not sure if that had any bad effect on it. Can someone please help on this as unit shows cassette playing. There is no volume switch on the unit itself as someone else recommended in the previous answer.
Posted on Nov 25, 2007
My technics cassette deck tr575 everything seems to work all the functions all the buttons but when I put a cassette tape in the unit I see no responce on the db meter... Everything is functioning on
There are 2 long switches, maybe 4" long, called record/play switches. These can certainly cause this. Try cleaning them with the power unplugged. You would turn the cassette deck on end, so the switches are vertical. Use LPS-1 or LPS-2, and spray a very small amount in the end. Work the switch back and forth and see if that helps. Good luck.
Nov 25, 2014 | Technics RS-TR575 Single Dual Cassette...
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 Dual - Won't Reverse
Cassette decks that have been sitting for long periods have problems with drive belts and idlers becoming slack or decomposing of the rubber compound. If you wish to keep the unit, please have it cleaned and have belts/idlers replaced with new ones by a professional service. Also have controls and switches cleaned of built up tarnish and mildew to prevent noisey or drop-out audio
May 11, 2008 | Technics RS-TR272 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 Single Cassette Deck Logo
713 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
