Question about Sunbeam Humidifiers
Model 699 Sunbeam humidifier manual - Sunbeam Humidifiers
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
SOURCE: sunbeam ultrasonic humidifier model 696-12
I want to order this rubber gasket
Posted on Feb 24, 2009
greenspan
  • 1734 Answers
SOURCE: Sunbeam 701 model humidifier
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 114 Answers
SOURCE: Vapor is not coming
from all the information that i have come across. the unit is a cool mist. the vapor won't be apparent for the coolmist. now if it was a warm mist there is something internal that isn't making it cause any vapor. but if you done all the normal troubleshooting and nothing still and it has a filter it will more likely be a cool mist. warm mists don't have filters
Posted on Aug 20, 2009
6ylucy
  • 742 Answers
SOURCE: I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Posted on Jan 03, 2010
Need a copy of the users manual
Sunbeam.com provides all their products user/owner manuals.
http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/instruction-manuals.html
Apr 16, 2016 | Sunbeam Humidifier. 3.23-Gallon...
I dont know how to add water to a sunbeam humidifier model#scm808
Hallo
Can you not find the owner manual?
The best I can do is advice you to go online and find MANUALSONLINE.COM. There look for the brand name "sunbeam" then the product humidifier.
In the one in this house you lift and take the filter out and water in.
Good luck
Kolbrun
Apr 23, 2012 | Sunbeam Humidifiers
I love the 696-3 humidifier but cannot find another on any suggestions?
Well, that's going to be difficult to do, as the 696 models have been discontinued. However, on the up side, parts are still somewhat available through a number of sources.
Sorry I didn't have better news for you.
Apr 21, 2011 | Sunbeam 699 Humidifier
I purchased a used Sunbeam Humidifier SWM5602 and need the manual. I have tried to search it and get a free copy so I know how to operate and clean it. Can you email me a downloadable copy of the manual?...
Lana, apparently that Model Number may have been discontinued. However, your Owners Manual may be available by calling Sunbeam Appliance @ 888 -264-9669.
Hope this helps you get the manual.
Rich
Mar 29, 2011 | Sunbeam 701 Humidifier
Missing gasket for the refill lid
It may quite hard to get original part replacement . Just find part replacement at local market ( EOM)
Jan 24, 2011 | Sunbeam 699 Humidifier
Sunbeam humidifier model 2422 will not reset low tank
I have a similar issue and this is a no filter warm mist humidifier. I just need to know how to reset it, but can't without manual that I don't have!
Mar 06, 2010 | Sunbeam Humidifiers
How often do i change the water in the sunbeam humidifier and can i put in some bleach to cleanse the air?
Bleach is not recommended, a mild detergent should work and you should just be adding water in the humidifier as it uses it. The humidifier should be drained when there is no more need for humidity
Jan 04, 2010 | Sunbeam 699 Humidifier
Humidifiers Logo
93 people viewed this question
Top Sunbeam Humidifiers Experts
Oloyede Monsuru
Paul Sikkema
Paul Sikkema
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
