Question about Frigidaire FDB1502RGC Built-in Dishwasher
WATER DOESNT PUMP OUT MODEL FDB1502RGC4
WATER IN BOTTOM OF DISHWASHER AFTER FINISHED
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Water backs up into the bottom of the dishwasher
Hello there:
When water backs up into the basin after the wash is complete this is a indication that you have either a filter that is clogged or you have a drainage hose clogging or the extraction pump it'self has a screen that may be clogged or the pump may not be working at all ok so check these things that i have mentioned and i think you will be ok after this ok?
Hope this is very helpful for you
Best regards Michael
Posted on Jan 05, 2010
Testimonial: "Thanks, I didn't know there was a filter"
heatman101
  • 43501 Answers
SOURCE: my dishwasher is holding water in the bottom like
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
HansPP
  • 2510 Answers
SOURCE: water is left in bottom of dishwasher after washer
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Feb 19, 2011
What does E25 mean on my kenmore elite dishwasher model no. 639.140031.
Indicates a drain problem. Either blocked drain somewhere or defective drain pump
Nov 14, 2017 | Kenmore Dishwashers
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
My frigidaire dishwasher FDB1502RGC4 will not run a cycle. it will fill and drain the water but will not run a wash cycle. all the lights on the control panel lightup when they should. so i dont think it...
having the same problem with mine, just replaced the discharge pump last week because it went out, worked a couple days now this. still have not figured out the problem
Dec 01, 2010 | Frigidaire FDB1502RGC Built-in Dishwasher
Water isn't flowing in through the spinners in the dishwasher.
Look at the end of the wash and no water in the bottom, it is OK. The water is pumped out through the pump. Hence you would have found the water mid way. Pump will start after the wash cycle is fully finished it's function or as per the float level!
May 31, 2010 | Viking 24 in. Professional Series VUD141...
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My dishwasher won't drain fully . It still has a bottom full of water after it finished the cycles. We took off the drain cover and it had a lot of "gunk" on the bottom of it. Gross!!! Help!
Usually there is an item called a flapper inside of the drain pump that will break off and plug the drain hose. Not easy, you must remove the pump.
Oct 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Machine doesnt drain properly
The following checks might help you out->
Check the sink drain and drain hose for restrictions
Unjam the motor
Unjam the pump
Check the drain valve
Check the drive belt
Please do post comments if the solution is not clear.Also to provide internal diagrams, so that the parts can be identified easily, please provide me with the model number. Please do rate my solution if accepted.Thank you for contacting Fixya.Good luck with the machine.
Sunny
Apr 08, 2009 | Dishwashers
Dishwasher not draining
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Dec 14, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Frigidaire FDB1502RGC Built-in Dishwasher Logo
79 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
