Can you keep the door open on the maytag Neptune front loader to keep the smell out?
    Sergeant:
  • 291 Answers
You should definately keep the door ajar when not in use. However it only helps, it will not cure your odor problem. Try a cup of bleach poured directly into the soap compartment of the dispenser (not the bleach compartment) and run the clean cycle. Again this only helps does not cure. Ultimately you will have to remove the bottom panel to access the drain pump. The first link below is a really good video that will show you how to get it out. Your screws are on the very bottom (i think) He is servicing a kenmore in video but maytag is nearly identical in it's setup. The next link shows you how to take the pump apart. Sounds hard and time consuming, but it's really not. That pump is full of black funk. Take it apart carefully or you will get funky too. When completed no more odor. Hope it helps:
http://www.youtube.com/watch?v=8gNPHXV62YQ
http://www.youtube.com/watch?v=2abTptUYXH8
Posted on Dec 07, 2012
  • 30 Answers
SOURCE: maytag neptune front loader
I would say that you have damaged your door lock. Most appliances have a door lock or a mico switch. this is the first port of call for the power to supply the w/machine.Safety measures??? go back to basics,is the door locking, any power to the going to the electronics. a door. Change faulty components???
Posted on Aug 15, 2007
  • 3 Answers
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
Lumpy816
  • 246 Answers
SOURCE: I have a Maytag Neptune
For replacing the nuptune boots, I belive these are all of the steps. First, take the 2 phillips screws out of the door hinges. You should be able to lift slightly on the door and pull it towards you to remove it. Also remove the 2 phillips screws straight across from them. This will let your front panel come of (grasp up top and twist slightly to get it off the clips. Lower the front down and you can remove it from the washer and set it aside. Remove the 4 phillips screws from your soap/ fab softner dispenser. Next, remove the 2 5/16 screws that hold the top on to the front of the washer.
To remove the boot, first, pull the front part of the boot towards you. It will actually pull off without much effort. On the bottom (depending on model) there will be a tube at the bottom of the boot that is either stoppered up or connected to a black hose. Squeeze the green clamp to remove the hose if it does have one. To take of the back half of the boot, we're back up top. Lift the top of the machine (you may want someone to hold it or just slide the machine far enough forward the top can stand up by itself). You will see a large spring connected to what looks like a piece of cable coated in clear plastic. Pull the cable towards the front by the spring. It will quickly contract.
Reinstalation time. Take your new boot and install the back half. As you work the boot on, you will see some triangles all the way around to help you line it up correctly. Once it is on, it's time to re-clamp. This is the tough part. Typically what I do, is I make sure the cable is wrapped around the boot from the bottom with the clips at the top. (there is a nice notch for it to fit into) Next I take one side of the spring and attach it to the clip on the cable making sure that the hook side of the spring points up. Now, grab the clip on the cable (without the spring attached) with a pair pf pliers. I use a pair of needle nose pliers to grasp the spring. Now I stretch the two of them together. This will not be easy and the spring will be under some tension. Once the spring is on the clip, lower the lid. (there will be a black wire harness on the right hand side that needs to be tucked back into place for the lid to close properly. Screw the lid down. Re-connect the hose at the bottom of the boot if your machine was equiped with one. Push the front part of your boot back on. Put your door back on the clips where it sits. Lift slightly on the door and swing it closed. Run a test cycle (fill, tumble and drain) while you are standing there to check for leaks. Once you have verified there are no leaks, replace the front panel and your screws. If you run into troubles, message me back.
Posted on Jul 04, 2008
aborcass
  • 2651 Answers
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Posted on Feb 22, 2009
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
Smell of mold and mold on rubber in front loader
If you don't leave the door open when not in use and not wipe the door dry and the door gasket dry, mold will build up as there is no air to let the moisture escape into. Makes sense, manufactures do no not say this in their manuals, I think they should !
Mar 20, 2010 | Maytag Neptune MAH6500A Front Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why does my Maytag Neptune Washing machine smell like rotten eggs everytime I turned it on? Maytag Neptune MAH7500AWW Serial 70802618ZM
you have mold built up around the door boot. you need to buy a package of a product called AFRESH (3 tablets in it). follow the directions on the package. use one a month for maintenance on this machine. also, make sure you do one or two hot washes per month to keep the hoses cleaned from build up of soap and or fabric softener. leave the door open a little bit after each load.
Nov 08, 2009 | Maytag Neptune MAH7500A Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer ??? Is there a filter ???
I was having that problem with smell too and I was told not to completely close the door when the washer is not in use to allow for air flow. When the door is always closed it does not allow for air flow and a mildew smell will develop. I keep mine open when it is not in use now and I do not have that problem anymore.
Apr 19, 2009 | Maytag Neptune MAH6500A Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mel dew on rubber around washer door
you would need to change the bellows gasket
Feb 24, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Front Door Load, Problem
Hello Yery1975
Welcome
You said, you have a situation with my washer machine (Maytag Neptune front loader). It was making the noise several times as latching the door, then if would go off and you could not open the door, You found the under soap deposit cord but the situation is not opening the door or no, it is getting he machine to work. Whichever cycle you press, the door makes the locking noise several times, sometimes the door can not be opened and the lock door light is off, the thing is that whichever cycle you try the numbers on the electronic pad would go down several numbers and then it will again make the door locking noise and will stop there, the start button begins flashing and the machine does not wash at all on any cycle, neither it spins or rinses. Can you please, please, help me? Ohooo... some times after trying and trying get the FL code... you have tried keeping it disconnected from the electricity for long periods, plugging it back and all you can think off.... but nothing!!!
You did the right thing
The Maytag Neptune had a lot of very different defects that Maytag was, and is aware of still.
That is why they discontinued that model .
But if you call Maytag service this time, you may find that it will be one of those defects in their design and an authorized Maytag person will recognize which fault is taking place.
perhaps they may cover the parts if you bring it to their attention.
Thank You
Please remember to leave a rating
Oct 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
