Question about Breville JE98XL Juice Fountain Plus
Won't turn on
The juicer simple won't turn on. The High and Low settings don't do anything.
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
http://www.omegajuicers.com/juicers/masticating-juicers.html
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
Big boss juicer won't work
I had the same problem. Mine completely stopped working after I put a small carrot in there. Can't find a customer service number for them. I did find an email for Antoinette Ramos. antoinette.ramos@emsonusa.com She emailed me back and said they would send me a new Juicer. Almost 20 days later, I have not received it and I can't get a reply email from her at all. I just looked at the email and her phone number is on there, so I will be calling. Here it is incase you still need it.
800-423-4248
Good luck.
Jayme
Aug 02, 2012 | Juicers
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Why won't my Jack La lanne's come on and it's new never been on
If there is not a flaw in the product itself it could be a problem with assembly or that the locking bar is not locked in place properly. The juicer will not operate if the locking bar does not click in to place in to the grooves on both sides of the lid.
Jack LaLanne has several HowTo videos posted that would be worth reviewing:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
You are also able to download a manual which includes illustrated assembly and disassembly instructions:
http://www.powerjuicer.com/power-juicer-manuals.php
If you are unable to lock the locking bar in place it suggests that some other component has not been installed in the correct position. Review the assembly instructions to make sure all pieces are properly positioned.
Thank you for using FixYa!
Oct 15, 2011 | Jack Lalanne Power Juicer 250 Watts
My omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
Sep 03, 2011 | Omega Juicers
Juicer does not turn on
Do you have the manual for you juicer? If so, see if there is anything listed in the back about trouble shooting and where to get help. If you don't could you write in with some more information about the make and model of your machine and I will look for some links to sites which may be able to provide assistance. Sorry not to be more helpful, but I could do with a bit more information.
Aug 22, 2011 | Breville JE95XL Juicer
I am trying to disassemble. I have done it many times, but the basket won't come off the base this time. I have poured hot soapy water through in forward and reverse. Not working
Many times when juicing very fibourous produce the bowl(basket) can get stuck and you can loosen it by gently tapping on the pulp spout or juice spout to the counter clockwise motion(right), this will loosen the bowl.
Aug 07, 2011 | Omega Juicers VRT330
My machine won't turn on when I flip the switch. It is properly connected, I tried it in several outlets - that are working for other appliances and I am left baffled. I haven't used it in about 6...
do you have user's manual with wiring diagram? if not try H.B. If you get one, there is a diode that keeps your machine from frying from over-voltage. Kinda like a fuse, but is not a fuse. If you can check voltage across it, it is not the diode. That is a simple start and the most common problem for not starting.
Aug 03, 2011 | Hamilton Beach 67601 Juicer
Breville JE98XL Juice Fountain Plus Logo
95 people viewed this question
Top Breville Juicers Experts
just-ice
Colin Stickland
Colin Stickland
eyecam
Are you a Breville Juicer Expert? Answer questions, earn points and help others
