Question about Ingersoll Rand Type - 30 Reciprocating Air Compressor 7.5 Hp, 200 Volt 3 Phase, ModelNo. 2475N7.5
220 plug hook diagram using 4 wires - Ingersoll Rand Type - 30 Reciprocating Air Compressor 7.5 Hp, 200 Volt 3 Phase, ModelNo. 2475N7.5
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: need plug hook up diagram
Hi dcrouch537
Found these pictures on another webpage..
This should make your wiring much easier
"A picture is worth a thousand words" Please take time to rate mehunter19_46m_1.jpghunter19_46m_2.jpg
Posted on Sep 07, 2011
I need a wiring diagram for a deep fryer that is hooked up 110 to go to 220 vac.
do not think that can be done . that is why they use converter plugs in europe
Mar 17, 2015 | Kitchen Appliances - Others
Blower motor installation
just check the wiring diagram and connect the two wires for the desired speed and put a wire nut one the third one.
Aug 08, 2014 | Emerson NEW A/C Fan MOTOR 1/4 1/6 1/8 HP,...
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
May 21, 2013 | Pool & Spa
Well water jet pump
the diagram is on the tin cover that covers the wires
Mar 23, 2012 | Plumbing
I need a wireing diagram for two elament electric water heater. Mine runs on 220 volt, my question is what about the common or white wire where do i hook it to or do I not need it when running a 220 circut
Links below show specific wiring diagrams and explain 240V with two hot wires vrs 120V with hot and neutral wires.
Then if you have more questions, add a comment and I will fill in blanks:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
First diagram will be for your water heater.
http://waterheatertimer.org/B220C.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Reliance & 40 Gal Electric Mobile Home...
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
We bought an electric dryer from sears outlet
220 Cords are usually color coded - BLACK, WHITE, RED, GREEN for Ground. Inside the dryer where you connect the wires should be the same colors. Just put the Black with the Black and so on. Make sure the plug is for a dryer and not a stove.
Mar 26, 2009 | Kenmore Dryers
Neptune dryer
there is no transformer in the dryer, i am guessing you have a 110 v motor and when you hooked the plug wrong, you could have supplied the motor with 220 v that's why you can smell something burnt.
the heater is 220 volts. regular dryer has dual voltage supply. 110 v and 220 volts.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I am running new 220 lines for my dryer and stove I would like to see a wiring diagram for hooking the new wire into the fuse panel.The existing service was gas.thanks
on a 220 set-up the green wire goes to the neutral bar where the white wires from the 110 breakers are connected. the two remaing wires, black and white go to the double breaker you will be using for power. it doesn't matter which wire goes to either breaker. at the power outlet that the dryer is the green wire goes to the ground (:-) the right hand side of this simple diagram, and it doesn't matter which of the two remaining wires hook up to the left side of the outlet (black and white)
May 04, 2008 | Dryers
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Ingersoll Rand Type - 30 Reciprocating Air Compressor 7.5 Hp, 200 Volt 3 Phase, ModelNo. 2475N7.5 Logo
125 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
