Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Where do i purchase the red,green and blue bulbs for a phillips 60pp9202
    Top Expert:
  • Philips Master
  • 14,553 Answers
I DOUBT those are available and the blue is about the only one I have ever seen bad.
What is the set not doing? ----may be able to help if I know.
Posted on Dec 06, 2012
  • 138 Answers
SOURCE: phillips 60pp9202 60 in
If the it is bowed in the probleis the convergence IC'S and the part number is 90035
932212344682 and contact www.andrews.com for a price.Get a service tech toinstallit.
Posted on Aug 19, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 60pp9202/17f color problem
Common problem. Your convergence chips and resistors need to be replaced. Check with the site www.TvRepairKits.com for parts and replacement instructions.
Posted on Dec 12, 2008
SD Tech
  • 14553 Answers
SOURCE: phillips 60pp9202.. too much blue
1.) As far as the coolant goes--it is clear and called Glycol---you just want to look to make sure you have no leaks---none has gotten on the circuit boards.
2.) If the blue will not move in some direction one of the two STK-392-120 CONVERGENCE chips this set uses is bad. There are also a number of 6.8 ohm light green resistors around them that need to be looked at and tested--The chips are on the left large board side by side on metal heat sinks(as you look from the back)---the resistors are in front and left to right around several plugs(convergence yoke plugs)if any of the resistors are white in the middle they need to be replaced along with both chips.
3.) You can buy the pair of chips on Ebay for about 13 dollars plus shipping--the resistors can be purchased at almost any parts place that sells TV parts--these places may also have the chips but usually charge a lot more then on Ebay.
4.) It all depends on how much soldering skill you have---You will need: Two new chips, Solder, a desoldering braid, liquid flux, heat sink grease, and some denatured alcohol----the flux makes it much more easy to unsolder the chips--lead free solder was used in these sets and it can be difficult to unsolder them---when you solder the new chips in apply liquid flux again.
5.) If you are able to do this repair you can save some real money as most shops TRY to charge 300-400 for this type of repair; I have done hundreds of them and here I charge 200-250 depending on the set.
6.) If you have questions or need advice contact me by replying to this posting.
I do this here for free so if this information has been helpful, take a minute and give me a vote here.
SD TECH
Posted on Sep 09, 2009
Testimonial: "Thanks SD Impressive! sounds like something i can handle.Thank you for the expert advice.how do you vote on here? 4 stars!"
SD Tech
  • 14553 Answers
SOURCE: My 2003 60pp9202/17 Projection can not sync red
If you went into the customer menu and red is skewed or warped etc and will not adjust it is not the Glycol or a comb filter.
This model uses two of the STK-392-120 CONVERGENCE IC's---if convergence problem--you will need to replace both of them and any of the 6.8 ohm protect resistors around them that are bad.
If you remove the back (unplug the set first) as you look from the back the large board on the far left will have two large metal heat sinks with fins on its right side---the chips are on the left side of them.
Take a good look with a flashlight at all the little green resistors in front of the front one and to the left of it--there are three plugs there--these are the protect resistors--if any are white in the middle--you found your problem.
Half the time only two will be gone---sometimes none.
Parts cost for this repair if you can do it yourself is about 25 dollars or less----most shops get at least 300 for this repair and some do not do it in the home.
Glycol or a comb filter will not cause the red to be out of position---some people here know more than others--
If you have some skill at soldering I can tell you the best place to get the chips etc and how to get at them.
I don't think this set is worth the type of shop repair that is needed--unless you are able or know a friend who can help you--it may be time to let it go.
IF YOU HAVE ANY QUESTIONS OR WANT MORE INFORMATION OR ADVICE LET ME KNOW---
I am here to help people--sometimes I cannot give them good news but if red will not move you have a convergence problem.
Regards, SD TECH
Posted on Oct 27, 2009
SOURCE: Phillips rear projection tv model #60pp9202/17f
you turn TV on , but no pucture nor sound, only a constant beeping (like a cricket) can be heard coming from inside back panel.
Posted on May 31, 2010
I want to replace the bulbs in my 60PP9202/17F but i cant find a place to buy them from. What type of bulbs(CRT, DLP, etc..) and where do I buy them?
You will need CRTs. There are three of them in your model Red, Green and Blue. You can get replacement CRTs from www.tvrepairworld.com that also have the CD with replacement instructions.
Mar 28, 2010 | Philips 60PP9202 60" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
Projector tv the red and green colors are not in sync
no its a convergence tube problem u shud change the green tube.
its the exausted one in this case.
Mar 15, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202
The only thing left is the SSB and that is your video processor 310432816308.
Aug 02, 2008 | Philips 60PP9202 60" Rear Projection...
Menue and multipoint
I fixed this tonight -- it was the convergence amps, which I purchased for $20. Thought it was the convergence board at first but it turned out to be the amps, which commonly fail after 3 years or so.
Dec 17, 2007 | Philips 60PP9202 60" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
