Question about Magnavox DV220MW9 DVD Player VCR
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
When you put the VHS tape in it starts to play for 5 seconds and then stops and the power shuts off. When you turn it back on the tape ejects. I have used many different tapes with the same result.
    Top Expert:
  • Magnavox Master
  • 14,553 Answers
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Posted on Dec 06, 2012
5 Suggested Answers
  • 8457 Answers
SOURCE: we just got a brand new dvd/vcr combo and the dvd
How do u hooking up this thing,up by a AV component video RYW signal cable to an analog tv,a LCD,plasma tvs or an a HDMI cable to a LCD or a plasma tvs?More informations please?
Posted on Dec 11, 2010
  • 2509 Answers
SOURCE: Sound goes up and down when recording with VCR
This is usually caused by poor contact between the tape and heads or the tape fluctuating as it goes through. First try a cleaning tape and see if that improves matters.Then get a friend to show you how to clean the tape path with alcohol and q tips.I assume there is no picture disturbance? There could also be other reasons like the auto level not working properly but start with the basics.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 25, 2011
SOURCE: ZV427MG9 A It will not record when recording from
same as above,check the mode swith.i's stuck in the dvd posision,you need it in the vcr mode to do that proceedure.
Posted on Oct 29, 2011
  • 504 Answers
SOURCE: just got vhs /dvd combo so i could record old vhs tapes to dvd it will not play the tapes it ejects them cant be dirt just out of box help
lance clean with lance cleaner comical and try
Posted on May 17, 2012
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
VCR Stops on me
Hello Ro Power,
This might be due to the tape sensor malfunctioning. You will need a schematic, and multimeter, and a LED power meter to work on this problem. When the tape loads it causes an LED sensor to become blocked and then the sensor tells the control chip that a tape is present and the the controll chip allows the tape to continue playing, if the sensor does not work the signal never gets to the control chips and since other events happend and triggered the control chip the control chip looks at this as an error and the stops the tape , some units even eject the tape.
If you do not have a background in electronics, I would suggest that you take the VCR to a qualified shop and have them repair it.
I hope this helps,
Thank You,
Shuttle83
Oct 17, 2007 | Quasar VHQ940 VHS VCR
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Dec 04, 2008 | Radio Shack Accurian ADR-0106
TV/VCR COMBO problem
My dear friend your problem is the charge motor belt who is in bad conditions you got ta replace him.Good luck.
May 28, 2008 | Zenith Televison & Video
VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Feb 25, 2008 | Emerson EWV403 VHS VCR
VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 18, 2007 | Funai PY90VG DVD Player/VCR
Magnavox DV220MW9 DVD Player VCR Logo
878 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
