Question about Fahrenheat Electric Hydronic Baseboard Heater, 240 Volt
Need wiring help with Fahrenheat PLF754 240V baseboard heater with Fahrenheat PT2DS double-pole thermostat
Open kimono - I know enough about electrical wiring to be dangerous. I have a Fahrenheat PLF754 240V baseboard heater and a Fahrenheat PT2DS (also known as Marley T2) double-pole integrated thermostat that and the heater isn't working. My power supply is a single cable with white, black, and red wires. I traced the supply line back to the circuit panel and found that the red and black wires terminate on a DP-40A breaker. The white wire is grounded. The heater has 2 red wires exiting a center tube at the end of the heater where the thermostat goes and 2 black wires exiting a small cut-out near the top of the same end. There's also a green ground wire from the heater. The thermostat has 2 red wires on the left top and bottom, 2 black wires on the right top and bottom, and a green ground wire. An electrician friend of mine (since left town) installed the wiring, heater, and thermostat for me. It worked fine for about 1 year and then stopped working. I'm trying to troubleshoot the problem but don't have any documentation on how this thing should be wired or how I might isolate the problem to the thermostat, heater, or both. I did verify that the power supply is good. Everything is currently wired as follows: Black power supply to black thermostat (top) Red power supply to black thermostat (bottom) One black heater to red thermostat (top) Other black heater to one red heater Other red heater to red thermostat (bottom) Green heater to green thermostat White power supply not connected - just wire-nutted Can anyone confirm this is the correct wiring for this configuration and, if not, what it should be? If this is correct, how best to isolate the problem? Thanks!
3 Suggested Answers
  • 147 Answers
SOURCE: wireing the baseboard heater
I can help you if you still here.
Posted on Nov 06, 2008
  • 86 Answers
SOURCE: Im hooking up a base board heater for the first
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Posted on Nov 04, 2010
Cadet baseboard heater
If I have your information right you have a black wire and a white wire marked red coming to the heater with 240 volts between them. You have a double pole unit mounted thermostat with a red and a black wire. Most double pole thermostats have two red and two black wires on them so I am not sure if you have a double or a single pole thermostat.There are also two wires going to the baseboard heater. One is connected to the element the other to a high limit switch which is then connected to the other end of the element. If the thermostat is a double pole the two red (or load) wires should connect one to each of the baseboard wires. The two black (line) wires should connect one each to the two incoming power leads. If it is a single pole thermostat the one red wire should connect to one of the baseboard wires the black should connect to one of the incoming power wires the remaining baseboard and power wires should then be connected together. Hope this helps
Dec 12, 2013 | Heating & Cooling
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
What thermostat do I use for a model f2546nwc heater where the thermostat is mounted on the heater
u have to use a double pole thermostat...u can find it a homedepot...it has 4 wires- 2 red and 2 blacks..i just installed mine on 11/7/10...
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
Good luck Dickson
How do I know if I have 240v when replacing old baseboard heaters
When you turned off the power to the heaters was the breakers a double (2 pole ) one? If so, then yes, it defintely is 240v. There are very few 110v baseboard heaters out there anyway. The best way to check is to have an electric meter and check it out for sure. Actually if you are working on electrical circuits and you do not have an electric meter to check if you have them shut down for sure, you are on dangerous ground. Always be safe and check before working on any circuit.
Nov 14, 2009 | Fahrenheat Electric Hydronic Baseboard...
Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
May 03, 2009 | QMark FBE15002 electric baseboard heater...
Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
Jan 29, 2009 | Fahrenheat FBE15002 Baseboard Heater
I have one thermostat for 4 electric baseboard heaters all in seperate rooms, i want to disconnect one of them how do I do it?
You have to shut the power off to all your baseboards, make absolutely sure that the power is off !!!!! once you are sure, then its a matter of unscrewing the unit from the wall, then opening up the panel, uncouple the wires inside the unit that supply the power, wire nut the wires then tape with electrical tape, if at all possible remove the power leads from the breaker panel that feeds that particular baseboard, if not, then make extra sure you have the power leads secure and taped off as so they will not touch together or anything else, I would strongly recommend that you hire a certified electrician to do this !! as this type of home repair is very dangerous and deadly. hope that was helpful
Jan 17, 2009 | Fahrenheat Electric Convector Baseboard...
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Hydronic Baseboard Heater, 240 Volt Logo
487 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
