Question about Sony DAV-S500 System
Sony Bravia KDL40W4500 Remote Control on Sony DAV S500
I have connected a Sony DAV S500 surround sound system to a Sony Bravia KDL40W4500 via the optical output on the TV to the optical input on the DAV. In the TV settings, i have changed the audio output from TV to audio system. I have changed the volume level from fixed to adjustable. I get sound fine...
My problem is, i cannot control the volume of the surround sound (or the TV output volume) via the bravia remote control. This is frustrating as i will need to use 2 remotes! Hate that.
Can anyone advise on how i can control the surround sound volume via the bravia remote?
Thanks,
Luke.
SOURCE: Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Posted on Jan 15, 2008
SOURCE: Sony BRAVIA DAV-HDX265 Changing the region code
buy a region free player :)
Posted on Mar 17, 2008
  • 34 Answers
SOURCE: problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Posted on Nov 06, 2008
  • 21 Answers
SOURCE: Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Posted on Feb 20, 2009
  • 26 Answers
SOURCE: i have a sony bravia 40v3000 tv and a sony
MOst TV's have fix or variable output find this on the TV menu & set it on or variable mode or fixed output mood.
Posted on Sep 20, 2009
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
Aug 14, 2010 | Sony DAV-DZ100 System
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Oct 15, 2008 | Sony DAV-S500 System
Dec 30, 2007 | Sony DAV-S500 System
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony DAV-S500 System Logo
90 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
