Question about Teac Audio Players & Recorders
Teac jc85 Loud hum from speakers when power up.
Teac jc85 lound sound from speakers when power up. There is a pop sound even with the power button not pressed.
DJYar
  • 41 Answers
SOURCE: Loud humming coming from subwoofer
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Posted on Sep 04, 2007
yeokeke
  • 5 Answers
SOURCE: Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Posted on Nov 24, 2007
  • 14 Answers
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
Posted on May 30, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: vizio p50 hdm lound pop nowno picture
Vizio P50 Death pop no more video.. gets sound.. 2 yr old set pais $1800 at costco.
Common Issue.. Called Vizio .. told me has lifetime full waranty.. they knew from pop and no video what was wrong.. ordered parts without looking at set. Sending repairman out all in lass than 1 week.
Just be nice when you call.
They tell you to unplug for 30 sec. Plug back in and hold powerbutton when replug... it doesnt work. Get kicked up to level 2 support... problem solved... as long as repair works...
Posted on Mar 22, 2009
My sub randomly started making a loud humming noise. The stereo was not even on at the time.
The humming sound is 60 cycles or a harmonic thereof emanating from poor filtering in the power supply. Better get the supply serviced before the speaker gets damaged.
Mar 21, 2015 | Audio Players & Recorders
Humming loud noise
Sometimes depending on what type of tire you have, they can be making the humming sound, other than that you'd have to give more detail as to where you think it's coming from, like the back or the front, the engine or the wheels, transmission?
Jul 02, 2014 | 2005 Ford Escape XLT
My teac MA-7 amplifier makes a very loud bang (rather a very loud clicking noise) a few seconds after I turn it on, and then every 5 minutes or so. Even with volume all the way down, even with no inputs...
All I can tell you is that if the noise is on both channels the cause of it has to be something that is both channels running to it or is something to do with the power supply. If the main amp channels are outputted by one device I would blame it on that. But if they are separate you will need to look elsewhere.
Jul 30, 2013 | Teac Audio Players & Recorders
Buzzing sound car stereo
A lound buzzing sound is an indication that the Driver (transistor) for the amplifier final is bad. This is not so much a buzzing and it is extreme in loundness.
May 05, 2013 | Chrysler concorde amplifier. radio. ....
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Hum in TEAC EX-M3 radio
(1) Is the hum out of both speakers?? (2) Is the sound distorted out of any of the speakers?? If the answer is yes to 1 and no to 2 then it sounds like one of the smoothing blocks or capacitors have gone down and requires replacement. If no to 1 then you probably have blown the output chip or taken one side of it out, check all connections to the speakers, try not to use tape joints which are unreliable. If you do have to piece the cable, solder the connections. Then replace the chip, Ian
Aug 13, 2009 | Teac EX-M3 CD Shelf System
Lound humming noise and color distortion
you will be able to fix it. the sound you heard was a color wheel.. the part number is bp96-00674a
Mar 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
23 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
