Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 will not power up
I have a customers Acer Aspire 5100 laptop, will not power up with battery or AC power, if the battery is defective would this prevent the laptop from powering up at all, how could I test the battery, I did test the power adpater and it is putting out the proper voltage.
  • 2 more comments
  • jrobertb557 Jan 12, 2009
    I checked the battery and no contacts are touching from what I could see, I also checked the laptop terminals and same thing no problem there
    I tried that and still nothing was hoping it was only the battery, not sure what else could be wrong with it,
    sorry about the rating first time I have been on this site
  • Dan rogers
    Dan rogers May 11, 2010
    It is doubtful that a dead battery is causing the machine to start. Did you check for any shorts on the battery terminals?
  • 413 Answers
Try to remove the battery completely and boot the computer. If it boots with no battery then you know its time for a new one
Posted on Jan 12, 2009
  • Dan rogers
    Dan rogers Jan 12, 2009
    Not too sure why you rated me with an I/A as we still were walking through the trouble shooting steps. But it was way inapropriate hope you can fix this on your own
  • Dan rogers
    You are the only one that can change the rating since you are the asker it is now locked by you.
I have lost my lead to my acer laptop aspire5100 series model number BL51 19v .474Acan you help.I am a mature age person thanking you Pat
There are two solutions to this problem, Pat.
One is to buy the correct AC adapter (Charger) for the laptop.
Two is to buy an aftermarket AC adapter that will work for your laptop, but will also work for many other laptops.
The above is from a quick search. Your search may be better. Just put Acer Aspire 5100 charger, in your search box.
2) From another quick search,
Would also like to commend you for your intelligence.
Stating the Voltage, 19V, and the Amperage, 4.74A ,is a really intelligent thing to do.
(The charger MUST have 19 Volts for the Voltage. The Amperage (Amp's, or A), can be more)
For additional questions please post in a Comment.
Sep 11, 2011 | Acer Aspire 5100 Notebook
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 22, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Acer aspire 1500 will not turn on
Try removing the battery and running the power directly through the power outlet. HP laptop dv6000 has the same problem.
Nov 06, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
Acer aspire 5100 won't stay on when booting on battery
replace the battery. Batteries usually only last about two years and it sounds like it just cant hold any more juice. To find a battery go to and type in the model of computer and push search. Sorry for the news but its an easy fix
Dec 30, 2008 | Acer Aspire 5100 Notebook
My acer aspire 3690-2050 has stop working
Can you be more speciffic? What were you doing when it stopped? Did it just shut off? Will it attempt to boot up at all? Are you using AC adapter or battery power? More info plz.
Aug 31, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100 start up problem
If you dont hear any beeps. Then most likely the motherboard is faulty.
Replacement parts can be ordered from
If you need more assisntace, let me know.
Mar 27, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
245 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
