Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
Sony lcd KLV32S300A turns on then shitsdown later 4 flashes
It turns on with a perfect picture and sound then after a short while just turns off and the front light flashses 4 flash over again.
  • michaelkisak Apr 13, 2009
    I have the same problem with my Sony LCD KLV-32S300A though mine flashes six times
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
  • 4 Answers
SOURCE: no picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I called Sony repair and they said to bring my set in for evaluation. They think it is just the back light. Maybe $300 - $400 to fix. If it is the panel I will scream!
Posted on Jan 30, 2008
  • 225 Answers
SOURCE: sony bravia-flashing red light
I would guess your power supply board is slowly disintegrating. It is hard to tell what it is, until it finishes frying itself out. Plan on replacing the power board soon, 1-3 months maybe.
Posted on Nov 14, 2008
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
  • 1039 Answers
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Posted on Apr 25, 2009
Sony tv kdl-46vl130, Turn the tv on, half of the picture is dark, leave the tv on for about 20 minutes, and the tv is perfect, and stays perfect no matter how long is watched, Turn the tv off, and come...
I didn't look up the model to see if its a LCD or LED, if its an LED it sounds like you have some lamps going out, try turning down the backlight settings and see if that helps
Nov 15, 2017 | Sony Televison & Video
Flashing Standby Light - Sony 40 in Bravia
Similar problem. Unplug for 36 hours solved the problem.
Aug 23, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv tunrns on then goes to stand by flashes 4 times & repeats
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony 46" rear projection LCD HD - picture and sound go on and off
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Screen went blurry 20 minutes later no picture no sound just red flashing light on front
These sets had bad welds in the gun assemblies of the picture tubes. Now, one of the tubes has failed (shorted) and the cost would be too high to replace all three.
Mar 02, 2008 | Sony KP-51WS510 51" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
