Question about Hagen Fluval 306 External Filter
Fluval 306 making noise in canister
Sounds like rock in fan
My LG French Door Refrigerator Cooling Fan makes noise.
fans that make noise in no matter what they put them in , most times has something stuck to blade that makes it spin out of balance , hence it rocks slightly from side to side and makes noise , ive found that formula 409 and a rag makes quick work of stuff stuck on fans
Nov 22, 2016 | LG Refrigerators
Peugeot 306 gearbox
look ur cars had already done 13 years i think the drive shaft tooths may be worn out or chk out the fitting of drive shaft positioned properly or not
Sep 13, 2013 | Cars & Trucks
I have a new 306 fluval cannister filter-the flow is not strong at all-just wondered, is it supposed to be a strong flow or gentle return back into tank?
A 306 should be quite strong, first check the flow regulator is fully open, check that the filter motor is the right way round on the filter bucket, check hoses, inlets and outlets for obstructions, try running without media in the filter bucket. Best to try this stuff in the bath!!!
Aug 15, 2012 | Hagen Fluval 306 External Filter For...
Is it true that Benjamin Franklin invented the rocking chair?
The idea that Ben Franklin invented the rocking chair haslong been legend. However, there is nohistorical evidence to support this claim. Some historians do say that his innovated the rocking chair that moves afan through kinetic energy.
May 29, 2012 | Furniture
Whirring noise
fuel pump getting weak i had this problim with my girls 1998 cavalier bought from rock auto .com for 124.98 fixit the problem
May 26, 2012 | 1998 Chevrolet Cavalier
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
I have a 03 trailblazer. There is a clicking sound that seems to be coming from the big fan in front of the radiator. It clicks when the car is idling or while driving. The sound reminds me of when a...
It sounds like your water pump bearing is shot. Water pump needs to be replaced. The fan clutch also needs to be checked out, the clicking could be an indication that the clutch is going. This may have happened because of the play in the water pump.
May 30, 2011 | 2003 Chevrolet TrailBlazer
Hagen Fluval 306 External Filter Logo
44 people viewed this question
Top Hagen Computers & Internet Experts
David Payne
David Payne
Are you a Hagen Computer and Internet Expert? Answer questions, earn points and help others
