Question about Toshiba 55SL417U 55"" 1080p LED-LCD TV - 16:9 - HDTV 1080p - 120 Hz
Led tv relay standby
There were no LED light up or screen turn on. When I plug in power, I heard the relay click on then off after 2 seconds. I check the 5V power, it is stay on even after the relay turned off. The 12V and 24V are gone after the relay off, which I assume is the normal thing.
SOURCE: Toshiba 42HPX95 wont turn on
I am having the exact same problem with my Toshiba 42HP95. From the information that I have been able to glean from the internet, it looks to be some sort of problem with the power supply or some other component of the power circuit. I am giving up and getting service
Posted on Jan 16, 2008
ginko
  • 19396 Answers
SOURCE: Turned off by itself, blinking red led at front
The clicking sound is the internal protection switch that kicked in because a fault had been detected.
First ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Mar 15, 2009
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
jerryg50
  • 1667 Answers
SOURCE: Toshiba 42hp66 has sound but no picture
Part of the power supply is in protect mode. There is most likely a short or something failed on one or more of the boards.
The service rep would swap out boards to locate the fault. Then he would leave the new board(s) in the set, and perform any necessary adjustments.
Take the set in for an estimate before approving repairs. There are many times these sets are not worth serving when they are out of warranty.
Jerry G.
Posted on Mar 05, 2010
tbreeze47
  • 3083 Answers
SOURCE: Our Toshiba 42HL196 TV refuses
If the tv doesn't reset after being unplugged awhile, there's an internal problem, and the unit will have to be serviced. Make sure the cable input isn't loose, and that the cable cord is good. Aside from that, there's not much you can do. Some cities have mobile TV repairmen that will service the unit in your home, and it's much more convenient. Look in your Yellow Pages under TV Repair.
Good luck, and hope this helps.
Posted on Mar 01, 2011
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
Nov 10, 2017 | Samsung Televison & Video
TROUBLE SHOOT LC-60E78UN TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 30, 2016 | Sharp Televison & Video
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Kv24fs120 dead set with two led blinks
Two-blinks of the "Diagnostic STANDBY/TIMER LED" indicates one of two things:
1) Horizontal Output (Q502) in shorted on the A-board.
or
2) IC702 is shorted (CB board)
Two-blinks of the diagnostic red LED is a " B+ Overcurrent" problem.
The red LED will blink 2-times, stay off for 3 seconds, then blink 2-times. The cycle repeats.
The circuit board is quite delicate. One should not attempt repairs (unless one has high quality vacuum desoldering equipment such as a PACE desoldering unit).
Feb 01, 2008 | Sony KV-24FV12 24" TV
Toshiba 55SL417U 55"" 1080p LED-LCD TV - 16:9 - HDTV 1080p - 120 Hz Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
