Question about LG DLE3777 Electric Dryer
Dryer door opens in the middle of drying.
My dryer door has just started opening in the middle of a drying cycle and turns the dryer off. I found if I push the door in at the top left I can reset the dryer and it works again. How do I get the door to seal properly so it doesn't keep opening up during the drying cycle?
    Top Expert:
  • LG Master
  • 9,472 Answers
Check the door strike and the plunger to see if one of them has broke.
Posted on Dec 07, 2012
Testimonial: "That was it. The door strike. I just had to tighten it. I hadn't thought of that but had checked the plunger. Works like new again. Thanks."
  • 3 Answers
SOURCE: dryer turns off before clothes are dry
YEAH ME TOO
Posted on Nov 02, 2008
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
arcadeforeve
  • 39 Answers
SOURCE: Loud screeching noise from dryer.
sounds to me like the nylon pieces that isolate the drum from the front of the door are gone, you may want to open it up and take a look at it. Is it an old dryer? Its either that or I suppose it could be the bearing in the middle of the back but I dont think it would be in only certain parts of a rotation, it would be all. Im sure the drum probably just ate through the nylon seperator.Theres not much else that only makes noise part of the time.. and theres not many moving parts.
Im not sure if there are replacement pieces for this but you can google it.
Posted on Apr 13, 2009
omaharox
  • 166 Answers
SOURCE: Our new lg dryer model #DLE1310w is not drying
Recheck the vent all the way to the outside and make sure the vent hose is not smashed behind the dryer.
Long time to dry complaints almost always are due to a restricted vent.
Remove vent to dryer and test a wet load if they dry ok then the house vent is at fault.
Posted on Jan 20, 2010
  • 3 Answers
SOURCE: DLG5988S gas dryer takes long time to dry cloths
How long is the exhaust venting system from the dryer to the outside, where it vents? The dryer is not equipped to push air through any pipe that is too much past 8-10'. Each 90 degree bend in the pipe adds 3-5', so a few feet plus a few 90 degree turns makes it nearly impossible for the dryer to do a good job drying clothes. I own a Tjernlund LB1 dryer boost fan and it works wonderfully - a great solution to drying clothes in a reasonable amount of time with much less wear and tear on my dryer.
Here is another idea - I recently opened up my dryer to fix a problem and found that the interior exhaust pipe - the part that takes the exhaust air out of the dryer, into the vent pipe on the back of the dryer and eventually outside - had become disconnected INSIDE the dryer. The dryer itself was full of lint and the air wasn't getting out of the dryer at all. If you have this problem you'll also have a lint problem, so check this out - it would be an easy thing to fix.
Posted on May 12, 2010
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
Apr 04, 2014 | Maytag EPICz Electric Dryer
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Dryer stopped running in the middle of drying cycle. Circuit breaker was checked and reset. The light inside dryer will not turn on when door is open.
check that you have power coming to dryer...check for burnt wires going into cord area...it also could have blown your thermal fuse. its best to have a electrical tester to check componants
Jan 14, 2011 | Maytag Dryers
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
LG DLE3777 Electric Dryer Logo
327 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
