Question about Singer Tiny Tailor TT700
My icecream not set and tased like meal - Singer Tiny Tailor TT700
  • Singer Master
  • 1,564 Answers
Don't know what this has to do with sewing machines... but ok.
Posted on Dec 07, 2012
Tension setting for straight stitch on husqvarva topaz machine
The standard setting when the machine leaves the factory is the midway point between high & low number. However, over time with use, that setting may shift. The ideal tension setting for your machine is when the top and bobbin threads meet in the middle of the fabric.
threads sewing machine tension Google Search
Jun 03, 2018 | Husqvarna Sewing Machines
What stitch setting do I use for a satin stitch?
Depending upon the machine, whether it is electronic or a manual setting, most settings for satin stitch are shown as a zigzag with Length being the primary changeable setting.
If you want a 1/4 inch stitch, your width should be set for 6mm. on an electronic machine with the Length at or about 0.3 mm.
On a manual machine you will have to adjust the length until you get the effect that you want.
In either case use a scrap of fabric to test your stitches and then record the settings that you like best.
Apr 26, 2017 | Sewing Machines
I changed broken needle but accidently both of them came out now the left needle does not stay in
Assuming this is a serger? Is there only one needle set-screw on the machine or one set-screw for each needle? If there are two set-screws, then you may have accidentally lost the set-screw for the other needle. If there is only one set-screw, both needles will need to be installed at the same time, hold them all the way up and simultaneously tighten the set-screw.
How To Change The Needle on the Brother Serger 1034d 4 Thread 2 Needle... (this machine has only one set-screw for both needles)
Some other machines, ie Bernina, have a set-screw for each needle.
Dec 09, 2016 | Sewing Machines
Why does my older dog pace all the time?
Some information for you
Dementia and anxiety in your older dog - What you can do ...
https://pathwithpaws.com/.../dementia-and-anxiety-in-your-older-dog-w... Feb 1, 2010 - I had to do this with my old dog Jake and it actually ended up with us both ..... He doesn't pace through the night, but he does start early (around ...
Pacing & Circling in Dogs - Pets
pets.thenest.com > Dogs > Dog Health And indeed this behavior does suggest something is very wrong. ... It's distressing to watch your dog pace and circle relentlessly. ... Cushing's disease is a common endocrine disorder in older dogs caused by an excess of the hormone cortisol.
The Special Needs Of Old Dogs - 2nd Chance
www.2ndchance.info/olddog.htm Most older dogs do best when they receive several small meals a day rather than one or two. ... Does My Old Dog Need A Supplement ? .... They may pace endlessly, vocalize, walk in circles, loose their housetraining and ability to interact with ...
Why does my 16 year old dog pace so much? ' Yahoo Answers
https://ca.answers.yahoo.com/question/index?qid... Mar 2, 2008 - Best Answer: A couple of things - or a combination of things. Old dogs tend to lose their sight and hearing, so they can't really tell what's going ... Why does my dog pace and whine around the house? 14 Sep 2011 Why does my dog circle and pace constantly? 9 May 2010 Why does my dog pace around the house? 21 Nov 2009 Why does my dog walk around in circles? 15 Nov 2007 More results from ca.answers.yahoo.com
Jan 25, 2016 | Miscellaneous
How do you change the default stitch length for the straight stitch.
A setting change while you are sewing should not happen. Sounds like you will have to take your machine in for service.
Apr 11, 2015 | Janome Memory Craft 9000 Computerized...
What is the normal tension settings for normal 4 thread overlocking
Depends on the Brand and Model. On my Bernina 1150, if the tensions are set in the middle, it is usually a good tension setting. Each machine is different though and with use, those settings may change. You should be able to start with all 4 tensions set in the middle and then, looking at how it stitches, you can adjust each tension as needed.
Mar 31, 2015 | Sewing Machines
Dont know how to adjust the settings
hi there, follow this set up of thread as shown on figures3054202.jpgthe set up of bobbins thread wind should be counter clokwise as shown on figures.
654a65c.jpg set adjustment for dial tension should be #3 to #4 and stitch set up
to #12 depend on fabric this set for cotton,polyester.
then set up all this and .have a nice sewing.you can also view swing on www.youtube.com on search box type sewing machine.
don't forget to rate me. thank;s
Apr 13, 2009 | Sewing Machines
Stop motion knob won't tighten
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin.
sewman7
Dec 03, 2008 | Sewing Machines
Tension factory settings for Baby Lock serger Model BL400
The factory settings are 4, 4, 4, 4, and width at M. Hope this helps.
Mar 03, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
20 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
