Question about GE Profile PDW8400J Built-in Dishwasher
I would like o know how to reset the dishwasher ,
The problm is that after i hooked it up , and latched it , it immediatly came with the following lights on rinse only , and heated dry , but no motions or activity of anykind .....any idea
  • SparkyO Oct 15, 2008
    mine (model PDW8480JSS) is doing this, and also it is not heating.
  • michaelcansl Nov 28, 2008
    the problem is that the dish will not stop beeping and for some reason you can't reset it. How do you reset the ge prfile quitepower6
  • 54 Answers
Cut the breaker off for 5 min.
Posted on Jul 04, 2008
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
I have a 665.16039401 kenmore dishwasher and the clean light continues to blink. I can not run any cycles
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... You say it blinks 7 times, pauses, and repeats, right? Well, 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually, the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. If the problem re-occurs, then the cause may be a bad heating element or a bad controller.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 24, 2012 | Kenmore 15129 Built-in Dishwasher
My GE dishwasher's door is stuck shut ~ I'm assuming a broken latch. I was told to fix the latch, the dishwasher has to be taken out from under the counter top (in order to get the door open). My...
Well I'll try to help you get this opened. I don't know how much space you have at the top side edge of the dishwasher. You need a long stiff rod like a metal clothes hanger straightened so it can reach from the side to a little past the dishwasher middle. You need to push it in between the door top and the dishwasher body up at the latch area. What holds the door closed is a flat metal piece with a plastic hook on the end facing down towards the floor. You need to try and get the rod under the metal piece and lift it slightly, hopefully to unhook the the door. If you can't do that, the only alternative is to pull hard on the door handle and you should be able to break the plastic part of the latch which will then have to be replaced. The part that should break is the top hook which would be an easy replacement, but I can't be sure thats all the damage to the latch that will happen. It may do some damage to the part inside the door also. This is last resort. I'll try to attach a parts breakdown of the tub so you can see the latch hook. Look at item #50
Jun 10, 2011 | GE Profile PDW9880NSS Stainless Steel...
Kenmore dishwasher clean light blinks
The computer needs to be reset. you may need to check the tech sheet that should have come with the dishwasher ( usually behind the toe panel) for directions on reseting it. If you cannot find the reset directions, let me know, I will have to look it up. thank you.
Jul 07, 2010 | Kenmore Dishwashers
Asko dishwasher starts and immediatly stops
Hi mike, thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ? Thanks, Macmarkus
Apr 22, 2010 | Asko 1595 Dishwasher
Hi Brenda. Sor[ry to hear about your troubles. If I was nearby I would come over and help you in person.
Read the reasons why your dishwasher may not be working and check as many as you can safely. Get back and let me know what you find. I will work with you as long as necessary to get this resolved.
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
May 27, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Re-Set the control panel
if you are getting blinking lights on your console you may want to open up the door and visually look inside of the middle portion of your console and you'll observe an opening. this opening is where the latch and strike comes together to enaged power to the power board. you can take a butter knife and press the latch hooks downward. when you press the latch hooks(located on the latch then look at the front side of your console panel (at the same while holding the butter knife inside the latch keeping the latch hooks press down, press a wash cycle (normal, rinse, potspans, etc) and see if there is any more flashing. If not, then there is a bad connection with the latch.
Jun 07, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch SMU70 Dishwasher latch
Replace the latch assembly, if it is worn you cannot repair it. Regards Engineer
Aug 05, 2007 | Bosch 24 in. SMU70 Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
333 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
