Question about Danby DDW1899WP Portable Dishwasher
How do i reset Danby DDW1899WP Portable Dishwasher
It wont clean and it leaks and it skips from rinse to dry please help
5 Suggested Answers
  • 11 Answers
SOURCE: Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
Posted on Jul 27, 2008
SOURCE: what is the funnel thing
The "funnel thing" is exactly what it looks like- a funnel. It's for adding the salt to the water softener located on the "floor" of the dishwasher:)
Posted on Dec 16, 2010
caroldon
  • 17129 Answers
SOURCE: i have a ddw1899wp danby i have a green power
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Posted on Nov 05, 2011
ercupa190
  • 12223 Answers
SOURCE: error code #4 on ddw1899wp danby dishwasher
see this possibles causes:
you must read your instruction manual and go to the section troubleshooting for fix it the error codes. If you do not have go www.fitness.manualsonline.com or www. retrevo.com
God bless you
Posted on May 26, 2012
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
Oct 15, 2016 | Danby 18 inch Portable Dishwasher in...
My DDW1899WP dishwasher stops cycling after pre-rinse. Beeps & drying light flashes.
must be why the friend sold it to you. Go to their website and type in the model number and see if there has been a recall on this unit.
Mar 04, 2015 | Danby Dishwashers
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Water softener
Marsena, I am at the point where I'm going to call a repairman. I'm very disappointed that I have a brand new appliance, and no means of having this issue handled. This is a great dishwasher otherwise, but I could not recommend it due to this problem.
Apr 13, 2014 | Danby DDW1899WP Portable Dishwasher
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
Dec 28, 2012 | Danby DDW1899WP Portable Dishwasher
What is the funnel thing that came with my dishwasher danby ddw1899WP?
Nov 23, 2010 | Danby DDW1899WP Portable Dishwasher
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
Danby DDW1899WP Portable Dishwasher Logo
110 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
