Question about Toshiba HDD2F22 MK5061GSYN Hard Drive HDD2F22
HDD formatted on one Win 7 HP laptop will not work when plugged into a different Win 7 HP laptop (different model)
I am formatting this hard drive on an HP 8570w. When I put the hard drive into an HP 6460b Probook (as a second harddrive), I get a message saying: "Does not contain a recognized file system. Make sure all required file system drivers are loaded ad that the volume is not corrupted." I know the drive itself is fine, as I can put it into other computers & all is well. It has something to do with this specific model of comptuer (6460b). I'm not sure what needs to be changed.
SOURCE: Need to format harddrive on Toshiba Satellite Pro 4300
here are a couple of links so ya can get a handle on things.... Just follow the instructions ya be all good.... http://72.14.253.104/search?q=cache:0sWcmSlxdlwJ:lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php+tutorial+to+format+laptop+hard+drive%3F&hl=en&ct=clnk&cd=2 www.youtube.com/watch?v=CEhbmJbAjPw
Posted on Aug 17, 2007
madhatter639
  • 260 Answers
SOURCE: formatting an external hard drive
Open up Folder Options\View\Show Hidden Files and Folders. Return to your Toshiba HDD. Do you see an hidden files? If so, try to delete them. You may have to change the Properties of these Folders\Files in order to delete them. BE WARNED, removing or deleting any folders or files that Toshiba placed in there could have negative affects on the way your external HDD runs.
Posted on Mar 18, 2010
  • 10406 Answers
SOURCE: Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Posted on Dec 14, 2010
bronk50
  • 27725 Answers
SOURCE: sir/madam My toshiba HDD2189 si damage.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
also
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
if this fails to fix the problem and you still want to format your hard drive
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
dont forget to vote
Posted on Feb 08, 2011
  • 2567 Answers
SOURCE: I bought thisToshiba Canvio 1TB
Since you have bought it just 3 months ago, I assume it is still covered by warranty. If this is true, I recommend you contact your vendor & discuss the possibility of having a replacement.
In case you need any further assistance, please feel free to drop me a note.
Posted on May 09, 2011
HDD is being shown as unallocated. But it has data.so without formatting how can it will be allocated .
format the hard drive any way as it has to be in a particular format for the system
Nov 30, 2015 | Computers & Internet
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
Oct 18, 2014 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I bought a LENOVO B 450 laptop. The dealer installed WIN 7. But in WIN 7 Tally 7.2 will not work. So I wish to install WIN XP. But when I tried to install WIN XP there shows an error message and a blue...
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
Aug 13, 2011 | Computers & Internet
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
I can't format my HP Compaq 6720s Notebook,win xp say can not hdd drive ,but i'll get new hdd
The reason XP cannot detect the hard drive is because thr hard drive in this model HP is a SATA hard drive and the Windows XP installation CD does not have the SATA controllers on this CD.
To install XP on a SATA hard drive, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 03, 2011 | HP Compaq 6720s Notebook
Toshiba HDD2F22 MK5061GSYN Hard Drive HDD2F22 Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
