Question about Mitsubishi MSH09TW Air Conditioner
Why is the air conditioner flashing HEAT
The word HEAT is flashing but no air is coming out of the unit.
  • Matthew Bornstein
    Matthew Bornstein Dec 06, 2012
    The unit needed to warm up. It eventually stopped flashing and then the Heat started to work. It did take about a half hour before it started working.
  • 3 Answers
A half hour is to much time!!, insuficient gaz installacion OR leak gaz installacion ,,
Posted on Jan 23, 2013
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
My Home Ac Unit Is Not Blowing Any Air
This sounds like the fan not turning during cool. You will have to check the fan relay for power during the cool cycle. The fan relay is run by the low voltage side, but still there is hi voltage present. When in heat the power goes thru the relay on one set of points then in cool goes thru the opposite side. You should have a digram present, and then on the main circuit board there is a code light. Check the light for blinking or (flash) read the bottom of the board for the code ( very small print)
May 17, 2010 | Goodman CKL24AR24 Air Conditioner
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
Power light is flashing and it isnt working
A multi split system is it? One of the reasons why the light flashes is because one indoor unit is on cool and the other is on heat. Changing the one on cool (or on heat) will fix this. Both indoor units need to operate on the same mode.
Mat
Jul 20, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Ray
Nov 16, 2008 | Ruud Handler Air Conditioner
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
Flashing lights and not putting out heat
Flashing lit cause of error, try to "off" and then "on' again the circuit breaker of the unit and restart
Jan 03, 2008 | Mitsubishi MSZ09UN Air Conditioner
Amana ptec unit built into the wall
SOUNDS LIKE YOUR HEAT STRIP IS NOT COMING ON THERE COULD BE A NUMBER OF THINGS TO CAUSE THIS,BAD RELAY ON THE BOARD BAD HIGH HEAT LIMIT,BAD T-STAT
Nov 13, 2007 | Amana PTC074B25AE Electric Heat Air...
Mitsubishi MSH09TW Air Conditioner Logo
43 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
