Question about Samsung PCL541R 54" Rear Projection Television
Samsung model pcl 5415r tv looks like its in 3d
Manual and auto convergence aren't working....tv is about 4 yrs old now.. is it worth fixing? is it easy?
tv looks like we should be wearing 3D glasses to view it.
  • 4,234 Answers
If this set is new, a problem like this would be covered by warranty. If it is no longer under warranty, locate the convergence ICs which will be large black ICs attacked to a heatsink. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace the ICs. These should be marked STKxxx.
Keep me posted,
Dan
Posted on Jan 13, 2009
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
PCL 5415R GHOSTING OF BLUE
It may be a problem with the ics, let me find schematics for your model
Apr 12, 2008 | Samsung PCL545R 54" Rear Projection...
ISamsung TV model # HC-P4363W
Check the tv out?If the tv have picture,colors R,G,B misalignment,picture have colors shadows,look like 3D pictures.The tv problems is it have a convergence problems.Very common on a DLP tvs.Very much repairables.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a samsung rear projection tv manufactured 2/2003. model #PCL 5415R. PROBLEM: convergence Need part number of convergence card and where to purchase it.
Please save your money and get this unit repaired, just because the set displays a "Convergence"SYMPTOM does NOT mean that changing that board will fix the unit, 9/10 it will NOT. I see this time and time again in the shop whereby people think they can fix their TV whatever, and mistake the SYMPTOM, for the cause and try to fix, usually unsuccessfully at that. The CAUSE must be repaired as well as the symptom, simply replacing a board will seldom "Repair" anything as the original fault that caused the symptom still has NOT been fixed. Please get a "Quote" they are free and at least then you will know what is the problem, even if you decide NOT to repair you have that information.Also one MUST have a Service Manual to be able to order the parts as without this number you simply cannot get parts.. it is that simple.
Mar 17, 2010 | Samsung PCL5415R TV
I know that I need a convergence power supply board.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 27, 2009 | RCA R52WM24 52" HDTV Projection Television
How do you align the colors
having same problem but our red is to strong how to adjust can we replace lamps ,are all lamps on one chassie i have installed chassie on NEC brand when i worked for the company yrs. ago .
my tv is 9yrs old do you think it is worth repair where can i get a sumattic to go by
Nov 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung PCL5415RB 54 Problem
Replace both convergence ICs number STK392-040 You can get replacements at the following link and they will provide free instalation instructions with pics and also give free tech support on line so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | Samsung PCL5415RB 54" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Tv wont stay on
Check for CRT coolant leak on PCB.Clean spill, try again to verify.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
165 people viewed this question
Henry  Thomas
Henry Thomas
