Question about Crosley CEDX631VQ Extra Large Capacity Electric Dryer with 5.9 Cu
Crosley dryer cedx631vq1 will not start but fuses are ok
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: crosley dryer
Let the machine sit for about an hour and try again. Let me know what happens. Would like to know the reason the motor was replaced.
Posted on Jan 26, 2008
  • 91 Answers
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
Posted on May 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: crosley dryer fuses where r they
The thermal limit is located on the right hand side of the heater chamber. The dryer will not run if it is open. SOME REPAIR PHOTOS
Posted on Sep 06, 2009
oldTech2332
  • 2341 Answers
SOURCE: crosley model ced5563rq, checked continuty
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
Posted on Aug 17, 2011
Crosley electric dryer get hot sometime and stop
Make sure your lint trap and all around the door, as well as your exhaust is not clogged. Probably have to remove the front of the dryer to clean it up good.
Sep 22, 2014 | Dryers
My dryer wont start at all. what could it be? a thermal fuse?
It could be either the thermal fuse or the door switch. You can check the door switch usually by just pressing it in and listening for a click to know that it is engaging. Here is a link to replacing the thermal fuse.
http://www.partselect.com/PS345113-Whirlpool-3392519-Thermal-Fuse.htm?SourceCode=1&SearchTerm=CEDX631VQ1&ModelNum=CEDX631VQ1
Sep 05, 2012 | Crosley CEDX631VQ Extra Large Capacity...
My crosley dryer cedx631vq1 stopped working I got a new plug cord now neeed to see how to hook up cord
Hi kathrynbr233...
Go to the following webpage and see a picture and information on how to hook up your dryer.
Please take time to rate me thumbs up
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 17, 2011 | Dryers
Crosley model ced5563rq, checked continuty on limiter fuse, door switch, off/on switch, checked heating coil, hi/low thermostats, circuit breakers and voltage. all seem to be ok. the dryer will not start....
GENE
Aug 17, 2011 | Crosley Dryers
Crosley dryer fuses where r they
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
Model #CDE6500W Crosley electric dryer has no inside light and will not start; the breakers in the house are ok it is like the power was shut off.
The fuse mounts beside the heater and the usuall cause for it to blow is a loose blower wheel or a ball of lint in the filter housing. Check out these repair pictures
Jul 24, 2009 | Dryers
good luck!
May 26, 2009 | Crosley CDE6000 Electric Dryer
Crosley dryer
Jan 26, 2008 | Crosley CDE6000 Electric Dryer
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Crosley CEDX631VQ Extra Large Capacity Electric Dryer with 5.9 Cu Logo
27 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
