Question about Philips Audio Players & Recorders
None of the cd tray is not opening top ones and the recording one at the bottom
I have press the display its say tray unlocd but none open
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Put a pin into the pin sized hole in the front of the tray and you are golden.
Posted on Dec 11, 2012
  • 275 Answers
SOURCE: CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Posted on Sep 20, 2006
SOURCE: FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Posted on Jul 12, 2007
SOURCE: Locked Cd Tray
The solution is to turn the machine onto standy and then hold the 'display' button for a few seconds, and voila, the trays are unlocked... geni-arse!
Posted on Dec 25, 2007
SOURCE: cd tray
Tienes que abrir el aparato y cambiar la banda de impulsion de la bandeja y darle mantenimiento al mecanismo del cd.
Posted on Mar 29, 2008
  • 5 Answers
SOURCE: cd ejection tray
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
Posted on Aug 11, 2010
Testimonial: "sir, many thanks for this , great to recieve info for the unit , its now working fine, good to be able to listen the sounds again ! "
Harman Kardon CDR2 2-Disc CD Recorder Left Tray Door sticks
these are not rubber bands they are belts and if you do not apply the proper ones you will ruin the motor, but it is the problem
Apr 01, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Locked Cd Tray
Aug 05, 2006 | Philips MC-90 CD Shelf System
90 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
