A DVD is stuck in the drive and won't eject with either the remote or button on the unit. Yes, the power is on.
SOURCE: I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
SOURCE: How do you retrieve a DVD that will not eject?
1st. turn off dvd and tv
2nd there is a small hole in the front of the dvd case,,usually close to the eject button.
3rd use a straight ,,slowly insert and you should feel a lever that will open the door. i,portant to so this slowly...
SOURCE: TV picture won't come on, just get white static
Hello
There may have some crack or loose to the circuit board during drop. Just get it serviced. No more component should be repalced. Only service should be done. OK.
