Question about Dryers
Replaced element in hotpoint ultima TCD 970 drier after F10 appeared on display panel and was blowing cold air after 1 dryer cycle F03 appeared on display on startedf to blow cold air again. what is F03 and how do i fix it
jsrock516
  • 5911 Answers
SOURCE: blowing cold air
There is not a reset button on an electric dryer that I know of. If a dryer is blowing air at all, that tells me that the blower assembly and drum motor are working. If you have not heat it is generally caused one of the following:
1. Bad thermal cut-out - located near the heating element housing. Should read a SHORT (0 ohms on an ohm meter) if good. If bad, it is generally a good idea to replace the TCO along with the Hi-Limit Thermostat (mounted right next the TCO in most cases) because the TCO is designed to protect the thermostat and heating element. If the TCO fails, it is likely that the thermostat could also be damaged.
2. Hi-Limit Thermostat failure - located near the heating element housing. The thermostat opens when the internal heat reaches about 157 degrees (on most dryers). This helps regulate the dryer temperature and helps protect the heating element. If it reads a constant OPEN (infinity reading on an ohm meter), replace it along with the TCO (as mentioned above).
3. Bad Heating Element - located under the drum on some dryer models and in the rear on others. The element should read about 9-11 ohms if good. If they go bad, the element will generally burns itself OPEN.
I will need you model number (located near the dryer door opening) in order to give you better advice on how to access the inside of the dryer. Post back with comments and let me know. I hope you find this helpful.
PS I hope I didn't insult your intelligence, but some people are little more saavy than others, so I try to explain things in the simplest of terms.
Posted on Jan 14, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Posted on Dec 16, 2008
meBNme
  • 334 Answers
SOURCE: my frigidaire dryer only blows cold air
You either have a tripped safety switch, a burnt element, or a burnt/loose wire to/from the element and or safety switches/controlls.
If you are handy, and have the tools, it should be a fairly easy repair.
You will need a volt/ohm meter to check the element for continuity, the safelty limit switches for continuity to lacate which part is the problem. (some switches are push button resset, some are one time trip and must be replaced.
The second issue is what caused it to quit in the first place.
The #1 cause for that type of failure, is lack of airflow due to a clogged vent pipe.
Make sure the filter, dryer outlet, pipt and outlet from the house is all clear from lint, birds nests, kinks etc.
Posted on Jan 16, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
F05 error code appears on the front panel and water will not empty but if i hold the waste pipe low into a bucket and the water then empties the cycle continues. machine is a hotpoint ultima wt900 1600...
hello there and thank you for choosing fixya
This is a verry common issue with these dryers Please read this solution fully below
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Jul 31, 2011 | Washing Machines
F 03 showing on machine
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Jul 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
F03
Good morning.
Error code F03 means that the wash thermistor is open circuit, this means that the water is not getting hot.
You need to fit a new thermistor first of all, if that does not solve the prob, then you will have to fit a new heater element as well.
You will normally find the element and thermistor located at the rear of the m/c.
Access it by removing lower rear panel
To get the parts, go to-----www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
250 people viewed this question
Top Dryers Experts
