Question about Locks & Locksmithing
Old Ilco Minute key machine manul
I need a manul for this old key machine I have.
2 Suggested Answers
  • 101 Answers
SOURCE: how to change belt on ilco 008b mini-mite key
To remove or install a belt on the Ilco 008, the shaft must be slid out of at least one bearing. If there is a guard cover over the pulley, remove it. Loosen the setscrew(s) on the cutter shaft pulley, and slide the shaft to the left. Mine is an older model, with no guard and the belt can be changed without removing the shaft completely.
After putting a new belt around the pulley, slide the shaft back into the right-hand bearing.
Be sure the pulley set screws are aligned with the flats on the shaft and that there is minimal end play and the cutter turns freely. Tighten the set screws and stretch the belt over the motor pulley.
Posted on Apr 22, 2014
RE-SETTING THE CODE
You need a key to unscrew and remove the lock cylinder on the inside of lock. Enter the old combination. Look inside the hole where the lock cylinder was and turn the metal part in there to the right. Then turn the knob or lever to clear the old combination.
Enter your new combination and turn the knob or lever to insure it works. Try it again to be sure, then replace the change plug. Always test combo with the door open.
Apr 22, 2014 | Ilco Kaba 101126d41 Lock Combination
How to make a house keeping authrization key
I don't know whether this can be done. I recommend that you contact Kaba Ilco directly for assistance:
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Code was forgotten and need to reset somehow. is there any way to do it by myself?
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the right-most column on the manual grid page, labelled "TIPS", and there you will find the files with the programming instructions.
As you will see, there is a reference in those instructions for the need for a DF-59 key. A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Also, there is a need for a spanner wrench. The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Kaba-Ilco Customer service can be contacted from this link:
Jun 20, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
How to extend or reprogram kaba machine expired date for authorised master key?
I can't help you directly, but I will steer you to further information.
May 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hello I'm having problems with trying to remove the override cylinder from the old cypher lock to install in to the new one. Is there a special way or special tool I need to remove it?
I can't help you directly, but I can steer you toward some information.
Feb 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do you zero out the Unican L1000 (with levers)? The lock is not responding to the old or new combination.
Yow will find a link to download the manual for your model L1000 on this page:
This will download a PDF file; you will need adobe reader installed to open it. There is a link on this same page to download adobe reader.
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I was relocating a working Kaba m# LL101126D41 i had happen to turn the outside handle with the small key cylinder removed on the back side top now when all installed it wont lock . what do ineed to do...
Oct 13, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Zero old key code and enter new key code on KABA electronic keypad
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14
Sep 22, 2010 | Simplex Kaba E-Plex 3000 Narrow Stile...
What key blank fits a brinks 5575 safe
My program shows 3 possible key blanks if it is a tubular key that fits this safe then the blank # would be Ilco 1137B, If your key has cuts on both sides of the blade then it would take an Ilco 1626, If it has cuts on only one side of the blank then it would take an Ilco 1531 I hope that helps if you have any more questions you can contact me thru my website at www.jambrilocksmith.org Bob
Mar 25, 2009 | Computers & Internet
Locks & Locksmithing Logo
61 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
