Question about Proform CrossTrainer Treadmill
Powered, but buttons do not function
The treadmill will turn on, but none of the buttons work. The safety line/switch beeps when actuated, but not the pre-set workouts, speed, incline, fan.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Please adjust the REED switch, TEST for open or faulty, clean it, and tight the plug or connector very well, see the diagram attached.
2) Tight the ribbon cable inside very well for keypads
3) replace batteries with the same types, same value, same polarity, and clean the contacts batteries.FULL charges.
God bless you
powered, but buttons do not function - 12_7_2012_3_44_21_pm.gif12_7_2012_3_44_52_pm.gif
Posted on Dec 07, 2012
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
  • 3 Answers
SOURCE: Treadmill will not maintain the correct speed.
your belt may not be tight enough and it is slipping which can cause it to move faster than the motor
Posted on Aug 26, 2009
  • 103 Answers
SOURCE: Proform 8.5 ifit treadmill will not start. Power
Hello There, Unfortunately the sound are hearing is caused by a stuck button on your console assembly. When this happens you will be unable to select any buttons due to this condition.
The only fix is to replace the console assembly.
If you go to iconservice.com you can get parts and pricing information.
Get your model number before going there. Should be (PFTL788072) and is located under the walk belt on the lower frame assembly.
Good Luck! Tim
Posted on Dec 21, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
Incline problem
All icon models are the same. The easiest way to incline calibration is to start the treadmill, push the incline up button and then after you release the button, remove the safety key. Replace the safety key and the treadmill should calibrate.
If that doesn't work, press the stop and speed up buttons and hold, then place the safety key in place. This will bring you to the speed/incline calibration. Press stop again. now press incline up. This will run the incline calibration.
You may need to remove the hood and manually with a drill lower the motor. Using a slot screwdriver bit, lower the motor a bout 50 turns and then try the procedure above again if necessary.
Mar 05, 2014 | Proform Exercise & Fitness
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 23, 2013 | Reebok Exercise & Fitness
Reebok vista treadmill
This type of treadmills seem to have high probability of failure if you use the emergency cutoff switch instead of the power switch at the bottom.
My guess is by yanking the red magnetic safety switch, the induced current put a heavy load on the central controller circuitry, and over the time it damages the IC chips on that board.
There's a border-line failure phase before the controller goes completely dead, I realized this and stopped using the safety switch, it hasn't had any issue ever since.
Aug 06, 2013 | Reebok Vista Treadmill - RBTL13305
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Console
Dear Sir:
See the diagram attached for Reed switch, clean, tight the connector very well.
2) Change batteries by new ones, and clean the contact very well!
sincerely. God bless you
Apr 25, 2012 | Proform ZT5 Treadmill
BUYER BEWARE!! I purchased the Nordic Track C2500 in 2009 and after 2 years of moderate usage (105 lb women walking 3-4 times a week) the console stopped working. None of the buttons respond and it beeps...
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Sep 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Treadmill will not start - say "Safe" on the Monitor
I'm not overly familiar with the Landice treadmills, although it sounds like it's not registering the safety key. Usually either a magnetic key or a slide key. Make sure your safety key is making good contact and if it's a magnetic key, that there's actually a magnet in it (sometimes they fall out without anyone noticing). If it's a key that you slide in to activate, see if there's any play in the port when you put the key in (wiggle it around) and if that works, the contact switch is slightly out of place. If the magnet is present and it's still not registering, either the reed switch inside the console has shifted and is too far away from the key magnet or it's malfunctioning (broken reed, shorted wire etc.)
Jun 01, 2010 | Landice L 7 Club Cardio Trainer Treadmill
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
Proform CrossTrainer Treadmill Logo
183 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
